Author Topic: v15.2β - QuickLinker: Associations in DB model diagrams  (Read 18597 times)
« on: June 15, 2020, 03:47:48 pm »
I think I may be falling foul of the perspectives issue again.
I can reverse engineer a DB with Database builder and I can create tables with the Data Modelling profile.
When I use the QuickLinker, should I be able to create an Association between the two tables?
TIA,
« Last Edit: June 15, 2020, 04:29:03 pm by Paolo F Cantoni »
Re: v15.2β - QuickLinker: Associations in DB model diagrams
« Reply #1 on: June 18, 2020, 09:11:20 am »
[SNIP]
TIA,
[BUMP]
We see NO Association on the list of QuickLinker relationships.  Since we need to create an Association BEFORE we can assign Foreign Key Constraints...  We "can't get there from here"!
« Reply #2 on: June 18, 2020, 09:53:55 am »
When I drag the quicklinker between two instances of EAUML::table I see Association (with the only other options being Dependency, Trace and Information Flow)
Yes, this will be dependent on perspective and the filter to toolbox.
« Reply #3 on: June 18, 2020, 03:35:20 pm »
When I drag the QuickLinker between two instances of EAUML::table I see Association (with the only other options being Dependency, Trace and Information Flow)
Yes, this will be dependent on perspective and the "filter to toolbox".
YMMVDWFM
I have a new diagram, type Extended: Data Modelling, Perspective: Data Modelling (via selective Toolbox Perspective = ALL Database Engineering).
"Filter to Toolbox" is OFF!
No other relationships than the "Three Amigos" above!
Where's my Association gone?
