Author Topic: A class has become an enumeration, in sympathy  (Read 5372 times)
José Farinha
« on: June 16, 2020, 09:52:53 am »
I've set the stereotype of a class to «enumeration». Strangely, another class connected to the former has also become «enumeration» and turned green.
The real problem is that I can't see a way to remove the stereotype from this class, because the stereotype field is now grayed out and the typical list of stereotypes has shrunk to a single option:
https://photos.google.com/photo/AF1QipO9jeFE6HBaCkCxZuzSNXiyZ4U5bdhS9oJ9S4Ne
Is this problem familiar to anyone?
Any suggestions?
Thanks for your attention
José
Re: A class has become an enumeration, in sympathy
« Reply #1 on: June 16, 2020, 02:17:46 pm »
Back in the old days enumerations where classes with stereotype «enumeration»
Then (in version 9 I think) they added the object type Enumeration. But EA is still sortof backward compatible with the old way of doing things.
Now to remove the stereotype click on the [...] and uncheck the enumeration stereotype. That will leave you with a regular class.
If you want to change your class into an Enumeration, use the Design | Element | Manage | Change Type menu option.
José Farinha
« Reply #2 on: June 19, 2020, 08:37:45 am »
Thanks, Geert. You saved me from a lot of work. But it was not straightforward:
I had already tried your first suggestion, but the problem was that the [...] button leads me to a list with a single option: «metaclass». That's the only stereotype available for enumerations.
The Design | ... | Change Type option worked, but only resorting to a trick:
1. I had to change my enumeration-class to an entity,
2. then the «enumeration» stereotype reappears in the [...] list and I could uncheck it,
3. then I changed the type back: entity -> class.
