Author Topic: How to get the correct size for a shape script shape  (Read 5076 times)
GrahamL
« on: June 22, 2020, 05:25:55 pm »
Hi
For my custom element I need an ellipse within a rectangle. This is relatively easy but when dragged onto a diagram the size of the element is wrong - there is an additional section at the bottom that means connectors drawn to the bottom of the shape appear disconnected.
Shape script is shown below, can anyone advise on a fix
shape main
   noShadow=true;
   DefSize(100,70);
   setfillcolor(255,255,255); // default is white
   // Draw a transparent rectangle to contain the shape
   StartPath();
   Rectangle(0,0,100,70);
   EndPath();
FillAndStrokePath();
   if (HasTag('GSN Status','Completed'))
      setfillcolor(0,176,80);
   if (HasTag('GSN Status','Work In Progress'))
      setfillcolor(255,192,0);
   if (HasTag('GSN Status','Behind Schedule'))
      setfillcolor(255,0,0);
   if (HasTag('GSN Status','Not Required Now'))
      setfillcolor(0,176,240);
    Ellipse(5,5,95,65);
Re: How to get the correct size for a shape script shape
« Reply #1 on: June 22, 2020, 05:54:03 pm »
Graham,
The statement
Means: give me a rectangle from the top of my shape to 30 % of the height of my shape.
So it leaves the bottom 30% empty.
None of the other statements fill in that bottom 30% either.
If you want a rectangle that fills the whole shape, then do
Rectangle(0,0,100,100);
You should think of all the parameters in shapescripts as percentages of the whole shape, not pixels.
PS. Same answer as here: https://www.sparxsystems.com/forums/smf/index.php/topic,44587.msg262835.html#msg262835
« Last Edit: June 22, 2020, 05:56:02 pm by Geert Bellekens »
GrahamL
« Reply #2 on: June 22, 2020, 06:08:32 pm »
Hi Geert
Thanks for the hint, but does this mean that all shapes have to be 100x100
What if I need my shape 100x70
Im finding this quite confusing!
THanks
« Reply #3 on: June 22, 2020, 06:33:48 pm »
Every shape is 100% height on 100% width
If you want your shape to be 100x70 you can set that in the default size
DefSize(100,70);
If you want your shape to have a fixed ratio of 100x70 then you can add
fixedAspectRatio=true;
GrahamL
« Reply #4 on: June 22, 2020, 06:50:49 pm »
Hi
This simple shape script still shows additional space at the bottom of the shape and I do not understand why?
shape main
   noShadow=true;
   DefSize(100,70);
    Ellipse(0,0,100,70);
« Reply #5 on: June 22, 2020, 07:00:17 pm »
Graham,
It's the exact same thing as with the rectangle. You are only asking to fill 70% of the shape with an ellipse, so the bottom 30% is empty
You should consider the parameters to Ellipse (and Rectangle, and others) to be percentages of the whole shape.
So you are asking:
Draw an Ellipse with dimensions
- from 0% of the width to 100% of the width
- from 0% of the height to 70% of the height.
and since you set default height to 70 pixels, the height of you Ellipse will be 70% of 70 pixels = 49 pixels
Uffe
« Reply #6 on: June 22, 2020, 07:07:20 pm »
Hi Graham,
Co-ordinates in shape script calls are relative to a 100x100 canvas. The actual size and proportions of that canvas can be controlled by the script or by the user, but the drawing methods always work on this 100x100 grid.
So in your case, DefSize(100,70); sets the actual (or external) size of the canvas.
Ellipse(0,0,100,70); then draws a squashed ellipse relative to the (internal) 100x100 canvas grid.
If you change it to Ellipse(0,0,100,100); you'll get a squashed ellipse filling the entire shape, since you've set the shape's size to 100x70. If you hadn't set that size, the same Ellipse() call would have produced a circle.
/Uffe
GrahamL
« Reply #7 on: June 22, 2020, 07:48:56 pm »
Got it!!
Must be monday :'(
