Author Topic: Make metaclasses and stereotypes selectable in profile model  (Read 15243 times)
Uffe
There are two very similar metaconstraint relationships; «metarelationship» and «stereotyped relationship». In both of these, you must specify the metaclass / stereotype as free text.
This is stupid.
They should be selectable from dropdown lists or selector dialogs, as is the case when you create a new metaclass or add stereotypes to toolboxes using the profile helper.
/Uffe
Re: Make metaclasses and stereotypes selectable in profile model
« Reply #1 on: June 23, 2020, 10:26:36 am »
Definitely wot 'e sed!
« Reply #2 on: June 29, 2020, 09:52:11 am »
Yes, it would be nice. In terms of the metaclass it could be a simple hard coded list. umlRole could be too, but ideally it would take into account the type for the source.
It's not so simple for the stereotype, which can be a stereotype in that package or an externally defined stereotype that may not even be available in the source model. Unfortunately, there's no tag type in EA that behaves even remotely similar.
