Author Topic: Specification Manager Requirement Table satisfy coloumn  (Read 4882 times)
kwasposer
« on: June 28, 2020, 11:38:04 pm »
Hello, i would like to create a table that  lists all requirement like the specification manager but with one more column where i can identify, how the requirement will be satisfied.
Thanks for any hint.
Re: Specification Manager Requirement Table satisfy coloumn
« Reply #1 on: June 29, 2020, 03:27:01 pm »
You could add a tagged value to the requirements where you fill in that information
kwasposer
« Reply #2 on: July 01, 2020, 10:24:34 pm »
Thanks Geert,
I created a block or a Property in my sysml BDD Diagram. Than I created a requirement which points to this block, so that I know, that this block satisfies the requirement.
Now I would like to create the Specify Table, where all requirements are listed in a table view. What I miss is, that I cannot see if a requirement is already satisfied in the model.
I was hoping that EA helps me with this, cause it already got this link <<satisfiedby>>.
SO the only solution is to create a tag, right?
« Reply #3 on: July 01, 2020, 10:36:27 pm »
No, you can also show the related requirements.
You can do that in a search window or in a model view.
Both will require some SQL to get the related requirements.
