Author Topic: item flow : flow properties versus properties  (Read 18322 times)
kwasposer
« on: July 02, 2020, 11:10:56 pm »
I had been reading that flow ports are not used anymore. There are only proxy and full ports, right?
How is it with the use of flow properties?
Do you use flow properties or properties for <<item flow>>?
Thanks !
Re: item flow : flow properties versus properties
« Reply #1 on: July 03, 2020, 07:51:39 am »
I assume you are referring to SysML. It's not true that flow ports aren't used any more. The FlowPort stereotype has been deprecated, but any port can be a flow port if its typed by a block that owns flow properties.
kwasposer
« Reply #2 on: July 03, 2020, 03:34:00 pm »
How is it with flow properties and properties? What do you use to defien flow items?
