Author Topic: Which Elements are typed by another Element  (Read 4701 times)
Viking
« on: July 03, 2020, 10:15:19 pm »
I would like to find out via the EA Object Model, which Elements are typed by a specific Element. Is that possible? Or only with a SQL-statement?
V.
Re: Which Elements are typed by another Element
« Reply #1 on: July 03, 2020, 10:52:57 pm »
If element.ClassifierID != 0 you have the element ID of the classifier. Just use GetElementByID to retrieve it.
Viking
« Reply #2 on: July 03, 2020, 11:59:28 pm »
Many thanks @qwerty. I'll try.
Viking
« Reply #3 on: July 04, 2020, 12:41:03 am »
If element.ClassifierID != 0 you have the element ID of the classifier. Just use GetElementByID to retrieve it. q.
I am sorry. I do not understand the solution.
Maybe my explanation of the issue was misleading.
I have a class A and a class B. Class A has an attribute a. This attribute a is typed with class B.
I want to find out, which classes (here class A only) use class B as type.
« Reply #4 on: July 04, 2020, 12:44:25 am »
You'll have to use an SQL query to get to the instances.
Use Repository.GetElementSet with this query as parameter
