Author Topic: EA 15.2 (Beta) Show Composite Diagram in Frame Size and Parameter failure  (Read 4066 times)
KThiel
    • Strypes
in EA 15.2 (also in EA 15) it is really annoying that the ability to show a Composite Diagram in frame feature is broken.
Link to screenshot: https://ibb.co/9hM8T2s
In previous versions (EA 13) it worked great.
On the original diagram I was able to adjust the size of the boundary, now it does this automatically.
On the previous version when I showed a Composite Diagram Frame I was able to connect to the parameters on the same position as in the original diagram.
Please fix this bugg
Kind regards,
Koen van Thiel
Kind regards,
Koen van Thiel
System integrator
e:    [email protected]
w:    www.strypes.nl
You need to send a bug report (link bottom right of this page). Doesn't mean it gets fixed, though.
KThiel
    • Strypes
Thank you, I have reported this as bug with the bug report.
Kind regards,
Koen van Thiel
System integrator
w:    www.strypes.nl
Takeshi K
    • Sparx Systems Japan
It might be avoided if you make the frame 'Selectable' - when 'Selectable', EA does not adjust its size automatically.
To be 'Selectable', right-click the frame header (top-right corner).
t-kouno
