Author Topic: HTML Generation not Loading MS Edge  (Read 25442 times)
philchudley
« on: July 15, 2020, 09:38:32 pm »
Hi All
My local workstation has upgraded MS Edge to Version 83.0.478.64 (Official build) (64-bit)
Now and HTML generated from EA fails to load in a similar way to Chrome (without the --allow-file-access-from-files switch)
Anyone else noticed this?
Cheers
Phil
Models are great!
Re: HTML Generation not Loading MS Edge
« Reply #1 on: July 15, 2020, 11:09:34 pm »
That's what I would expect yes.
Loading from local HTML files is considered a security risk
« Reply #2 on: July 16, 2020, 12:21:13 am »
Because it's local and already on my machine? What logic is that?
« Reply #4 on: July 16, 2020, 12:58:28 am »
Thanks Geert, not going to discuss that here. But step 1. of the 2nd link is already where I think: serves you right to click anything that appears to be a button :-/ Would just be better to have keyboards (and mice) with integrated mouse traps. Ouch.
Richard Freggi
« Reply #5 on: July 16, 2020, 03:08:11 pm »
Javascript and activex have no place in a modeling tool... even less in a distributable html report.  Still can't understand why EA uses them at all.
jennifer.cui
« Reply #6 on: July 01, 2021, 04:12:24 am »
so is there a workaround that will get the HTML page to load from a local drive on Microsoft Edge or Chrome?
philchudley
« Reply #7 on: July 01, 2021, 05:04:24 am »
For Chrome yes
Assuming you have a desktop shortcut to launch chrome, using the Shortcut's properties add this to the area specified as Target
For example, on my desktop the target for the shortcut becomes:
"C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" --allow-file-access-from-file
As far as I know, there is no work around for the latest build of Edge
Phil
Models are great!
philchudley
« Reply #8 on: July 01, 2021, 05:37:33 am »
Further to my earlier post, I have found a way to load local HTML files generated by EA
The trick to enable Reload in IE mode as described in the following link
https://pureinfotech.com/enable-ie-mode-microsoft-edge-chromium/
Once enabled, attempt to view the page, and when it fails, click the ...  button (top right in Edge) and select More Tools -> Reload in Internet Explorer Mode
This will make Edge behave as if it were IE, and yes you get the prompt "It appears you have Javascript disabled", as per usual.
There is a heading recommending MS Edge but otherwise the appearance is the same as when viewed in IE
Hope this works for you.
Phil
Models are great!
Space_Fan
« Reply #9 on: July 08, 2021, 06:07:58 am »
Thank you for the tips. I tried them and they still didn't work.
Then I went back, and did another export of the architecture, and it worked fine.
So go figure.
mbormans
  • Working on behalf ot the Belgian Insurance sector.
    • Telebib2 centre website
« Reply #10 on: February 15, 2023, 04:58:07 am »
if this solves the problem, at least in chrome... :
then...
in the "publish as html" window - there is the "view" button...
could we/you not allow to "parameter" what is behind/in that button, so that at least there, we could view the html just generated correctly...
I mean, clicking such button would call/launch the browser with the correct parameter... and would do this only there...
Michel Bormans
Telebib2 centre - Datassur - Assuralia - Belgium
« Reply #11 on: February 15, 2023, 05:31:38 am »
then...
The problem is solved in v16 as the current HTML export doesn't rely on these problematic scripts.
ducatiross
« Reply #12 on: March 01, 2023, 11:17:01 pm »
Geert is right - if I generate HTML in version 16.1, it loads correctly in Edge. Haven't tried it in Chrome.
