Author Topic: Custom Prolaborate log folder  (Read 46832 times)
Guillaume
    • www.umlchannel.com
« on: July 16, 2020, 08:41:49 pm »
I have a client which IT department requires to write log files on a dedicated location e.g. E:\logs\Prolaborate
I can customize it for the PCS logs via the config file.
Would it be possible to set a different folder for each log file? Is the following list complete?
C:\Program Files (x86)\Prolaborate\WebApplication\VirtualAssets\AccessLogs
C:\Program Files (x86)\Prolaborate\WebApplication\VirtualAssets\ErrorLogs
C:\Program Files (x86)\Prolaborate\Engine\EnginePCSLogs
Note: in Prolaborate Service Management, I can see the Access and Error log path as read only values to copy. It would be interesting to update them from here.
I noticed the following in the web.config that can be changed. Can you clarify what it does?
<add name="TextWriter" type="System.Diagnostics.TextWriterTraceListener" initializeData="c:\logs\SAML\idp.log" />
Guillaume
« Last Edit: July 16, 2020, 08:45:16 pm by Guillaume »
Guillaume
Prolaborate Support
  • Prolab Moderator
    • Visit us
Re: Custom Prolaborate log folder
« Reply #1 on: July 21, 2020, 05:20:51 pm »
Hi Guillaume,
Thank you for the suggestion. As you have mentioned this as a critical item, we have planned to consider it in the next release. Feasibility checks are yet to be done by the way!
There are some more log folders. Here is the rest of the list:
  • Mailer error logs - C:\Program Files (x86)\Prolaborate\Mailer\ErrorLogs
  • Mailer information logs - C:\Program Files (x86)\Prolaborate\Mailer\InfoLogs
  • Service Management logs - C:\Program Files (x86)\Prolaborate\ProlaborateServiceManagement\Logs
  • Prolaborate Install/Upgrade logs (IIS, Registry information) - C:\ProlaborateLogs
  • Prolaborate Install/Upgrade logs (Information on Prolaborate Engine, WebApp, etc.) - C:\Program Files (x86)\Prolaborate\InstallLog
  • SAML error logs - c:\\logs\SAML\Idp.Log  - You can set a preferred location for SAML error logs as of now from web.config file
« Last Edit: July 21, 2020, 05:33:48 pm by Prolaborate Support »
Guillaume
« Reply #2 on: July 21, 2020, 07:36:04 pm »
Thank you for your support  :D
Guillaume
Guillaume
« Reply #3 on: February 27, 2021, 12:40:07 am »
Thank you the implementation of this request via the latest 3.4.0.0 release https://prolaborate.sparxsystems.com/resources/documentation/manage-prolaborate-services?articles=logs
Guillaume
