Author Topic: Connector Line Jump with Archimate  (Read 33276 times)
Guillaume
    • www.umlchannel.com
« on: July 16, 2020, 10:53:20 pm »
A client is using Archimate with EA and noticed that the "line jump" doesn't apply to connectors such as Triggering (control flow), Serving (association), etc.
Only a few combinations work e.g. Composition + Aggregation, Composition + Association.
Is there a way to fix this?
Guillaume
Viking
Re: Connector Line Jump with Archimate
« Reply #1 on: June 04, 2025, 12:15:25 am »
Hi, I have the same issue. For a better readability of a diagram, I wanted to use “Connector Line Jumps”. The lines are based on “Archi Mate3:: Archi Mate_Serving“. But my lines do not “jump”.
  • “Enable Connector line jumps“ for diagrams is checked. So, that is not the reason.
  • From the manual “Diagram Options” I learned that only “solid-line connectors” are supported by “Enable Connector line jumps“. Serving is solid-line connector.
  • In https://sparxsystems.com/forums/smf/index.php?topic=23388.0 I learned from KP that “line jumps aren't available for shape scripted lines (which rules out most MDG Technologies)”. So, I suppose Serving is one of the affected connectors.
  • I changed the type of “Archi Mate3:: Archi Mate_Serving“ connector via “Advanced” > “Change Type” to “ControlFlow”. Now the jump is supported, although the stereotype stays “Archi Mate3:: Archi Mate_Serving“. To the connector the name “«Archi Mate_Serving»” has been added.
My questions are:
  • If I understand the above correctly only standard UML relationships are “really” supported (beside some exceptions maybe). So, most of the notations in SparxEA are affected, right?
  • Why does “type change” work, although it is still a stereotype?
V.
« Last Edit: August 26, 2025, 10:11:52 pm by Viking »
