Author Topic: Class Derivation - Different behavior in two different PCs  (Read 3562 times)
ranjit.selvaraj
« on: July 22, 2020, 03:36:04 pm »
In case we create a derived class, out of a parent class, using the class relationship "Generalization", in some PCs, the ports of the parent class are not derived to the child class. (They do not appear in the Features-->Interaction points of the derived class)
Enterprise Architect
Editon : Corporate
Version : 14.1.1428
Extensions :
Other Addin :
Operation Systems : Windows 10
System Type : 64bit
Connection Type : Local Project
Repository Type: eap
Not reproducible in all PCs, since only in some PCs we encounter this issue.
Uffe
Re: Class Derivation - Different behavior in two different PCs
« Reply #1 on: July 22, 2020, 04:21:17 pm »
Hi Ranjit,
Please note that this is a user forum, not a support channel.
In order to get a response from Sparx, you must send a bug report.
/Uffe
ranjit.selvaraj
« Reply #2 on: July 22, 2020, 04:25:47 pm »
Hello Uffe,
I have also sent a bug report, Just want to check if anyone has already faced this issue and already have the solution.
Thanks for your response.
Regards, Ranjit
Uffe
« Reply #3 on: July 22, 2020, 10:38:44 pm »
Ah, that's alright then. Just making sure since it was your first post.
For myself I've never seen anything like what you describe, where performing the same operation on the same version of the same edition yields different results on different hosts.
Could there possibly be some issue with user security permissions?
I know in the past EA has sometimes omitted locking embedded elements (ports) when locking the parent element, so if you're using user security that might be a place to look.
/U
ranjit.selvaraj
« Reply #4 on: July 22, 2020, 10:47:07 pm »
We use user security and the locking of ports is also identical in both the hosts.
