Author Topic: Use Excel with Javascript  (Read 6435 times)
Guillaume
    • www.umlchannel.com
« on: July 23, 2020, 11:05:00 pm »
I need to write a script in Javascript that creates and saves an Excel file but I'm getting errors. SpiderMonkey Mozilla site only has the following page and the info is not relevant + marked as obsolete: https://developer.mozilla.org/en-US/docs/Archive/Web/JavaScript/Microsoft_Extensions/ActiveXObject
The following leads to a "Class not saved" Exception
var oExcel = new COMObject("Excel.Application");
the following works ok:
var oExcel = new COMObject("Excel.Application",true);
I can see a Microsoft Excel process created in the task manager
The following generates an error : oWorkbook.sheets is undefined
var oWorkbook = oExcel.Workbooks.Add;
var oWorksheet = oWorkbook.Sheets.Add("",1);
Is there an example to create an Excel file and save it?
Guillaume
Guillaume
Re: Use Excel with Javascript
« Reply #1 on: August 05, 2020, 03:52:08 am »
I have a number of examples in vbscript: https://github.com/GeertBellekens/Enterprise-Architect-VBScript-Library/search?q=excel&unscoped_q=excel
In theory they should translate quite easily to Javascript.
Guillaume
« Reply #2 on: August 05, 2020, 06:21:19 pm »
Hi Geert,
Thank you for the link. Your Github project is really useful for VBScripts.
Unfortunately I'm struggling in the initial steps to initialize my Excel workbook.
Once "var oWorkbook = oExcel.Workbooks.Add(true);" is run, if I try to manipulate oWorkbook, it says that it's undefined.
Hence the need to have a simple example that creates an Excel file using a Javascript EA script.
Guillaume
Guillaume
« Reply #3 on: August 05, 2020, 06:32:25 pm »
I can't really help you with that. Not too much examples to be found on the web for javascript.
I did find a page suggesting that you might need to use method CreateWorkbook(), but I'm not sure if that is relevant at all
https://docs.microsoft.com/en-us/office/dev/add-ins/excel/excel-add-ins-workbooks
Guillaume
« Reply #4 on: August 05, 2020, 09:46:49 pm »
I'm hoping to get some info from Sparx on getting this to work.
Guillaume
Uffe
« Reply #5 on: August 05, 2020, 10:35:20 pm »
Are you positive that the same script works when run outside EA?
I'm not too sure about that Workbooks.Add() there.
/Uffe
Guillaume
« Reply #6 on: August 06, 2020, 12:06:49 am »
The JS code I shared doesn't work but translating existing /working JScript or VBScript code (based on Geert's examples for instance) to similar calls in Javascript doesn't work either.
Hence I'm looking for a functional set of code to open an Excel file, read and write its content, and save the file.
One of Javascript advantages is its class support. I managed to get a Logger class to work and that's great. As an Excel process is started by creating an Excel.Application COMObject, I suppose this is supported. I don't have any feedback from Sparx support yet. Since I understand SpiderMonkey/Javascript is recommended by SparxSystems, functional samples to quickly move from VB of JScript should be available.
Guillaume
« Last Edit: August 17, 2020, 09:05:49 pm by Guillaume »
Guillaume
