Author Topic: Control Flow missing in Quicklinkers for Actions of kind Call Behavior  (Read 5471 times)
dgoetz
Control Flow is missing in Quicklinkers for Actions of kind Call Behavior - sometimes. Depends on the assigned classifier.
If no classifier is assigned to an Action, then Control Flow pops up in the Quicklinkers. But if a classifier is assigned to an Action, then Control Flow is missing in the Quicklinkers.
Even if Filter To Toolbox is unchecked.
Is there any worlkaround, maybe with Meta-Constraint connectors in an UML profile?
Thanks for your support.
What version of EA are you using? I'm sure this has been fixed quite recently. For example, I just tried the latest 15.2 beta and it works on that.
dgoetz
I am using 15.1.1528. I will check with the latest beta.
Uffe
If you search for my posts with the word ControlFlow in them, you'll find a bunch of problems which may or may not be related, although I can't tell you off the top whether they've been fixed.
This thread is probably the most relevant, my last message there has a list of some of the problems I've encountered.
/Uffe
dgoetz
Re: Control Flow missing in Quicklinkers for Actions of kind Call Behavior
« Reply #4 on: August 06, 2020, 11:06:41 pm »
Thanks Uffe for your reply.
I know this thread. I had a lot of problems with MDG quick linkers after the update from 13.5 to 15.1. Fortunately most of them are solved.
The missing ControlFlow is back in 15.2.1552beta.
