Author Topic: Publish profile doesn't check for empties  (Read 4029 times)
Uffe
« on: August 06, 2020, 06:02:49 pm »
Hey all,
If you create a «profile» package with just a diagram and nothing else in it, then try to publish either the package or the diagram as a profile, EA flashes an error message and does not create the specified file.
Messages from an eapx repository on Windows 10/64 running EA 1512:
  • Package: DAO.Database [3075] Syntax error (missing operator) in query expression 'Start_Object_ID in () or End_Object_ID in ()'.
  • Diagram: DAO.QueryDef [3075] In operator without () in query expression 'Object_ID in'.
Publishing an empty diagram as a pattern doesn't produce this error, and does produce the intended file.
/Uffe
Uffe
Re: Publish profile doesn't check for empties
« Reply #1 on: August 06, 2020, 06:06:22 pm »
And reported.
Uffe
« Reply #2 on: August 06, 2020, 06:18:21 pm »
They don't fail at the same point, either.
The package one gets as far as storing the profile data in t_xref, but the diagram one doesn't. So it's not One Simple Thing, it appears.
Maybe the two functions have completely different underlying implementations? Shock! Horror! Surprise!
