Author Topic: Repository.SQLQuery() treats empty string values as bin.base64  (Read 3927 times)
Uffe
Hey everybody,
Repository.SQLQuery() goes crazy and starts hallucinating binary data when face with an empty string in the query results.
Instead of returning just an empty or self-closing XML tag, you get
    <ColumnName xmlns:dt="urn:schemas-microsoft-com:datatypes" dt:dt="bin.base64"></ColumnName>
This is on 15.0.1512 on Windows 10/64 and an eapx repository.
Can someone check if it's still broken in 15.1 or 15.2?
Try
Code: (VBScript) [Select]
Session.Output Repository.SQLQuery("Select null as NullVal")
Session.Output Repository.SQLQuery("Select ' ' as SpaceString")
Session.Output Repository.SQLQuery("Select '' as EmptyString")
Null gives a self-closing tag.
A string with a whitespace gives an XML tag with a whitespace.
An empty string gives the result above.
/Uffe
Re: Repository.SQLQuery() treats empty string values as bin.base64
« Reply #1 on: August 07, 2020, 09:23:33 pm »
Can't do that on EAP. Sorry.
