Author Topic: Internal application error - GetElementByID  (Read 7972 times)
eisaachsen
« on: November 21, 2012, 06:27:27 am »
I am using Java to access an EA model.  Here is a small snippet of my code.  I want to be able to get a package's parent's GUID, but I get a java.lang.exception (Internal application error) when GetElementByID is called.  The parentID just before it fails is 1.  What am I doing wrong?
int parentID = pkg.GetParentID();
System.out.printf("parentID=%d\n", parentID);
Element parentElement = repository.GetElementByID(parentID);
pw.print(parentElement.GetElementGUID());
g.makulik
Re: Internal application error - GetElementByID
« Reply #1 on: November 21, 2012, 07:14:34 am »
Did you check
Element parentElement = repository.GetElementByID(parentID); returned a valid result and/or
parentElement.GetElementGUID() executes correctly?
« Reply #2 on: November 21, 2012, 11:37:11 am »
You've got a Package ID not an element id. You want to use GetPackageByID (which returns a Package).
