Author Topic: Extending Multiple Metaclasses  (Read 5595 times)
Jayson
« on: August 12, 2020, 10:07:24 am »
Hi there
So looking at the Sparx documentation and profile helpers, it appears that you can extend multiple metaclasses when creating a stereotype.
I have also noticed that:
* Each metaclass has a distinct sub-set of the metaclass attributes, and
* The same stereotype can have the same property (for example "Source Navigability" for each of the metaclasses). For example, I could have a stereotype with "Source Navigability" = x for one metaclass and "Source Navigability" = y for another.
So my questions are:
1. Why and when would you want to do extend multiple metaclasses?
2. What happens to a stereotype that has multiple conflicting propeties (as above)?
Am I the only one that finds this super confusing?
Thanks in advance.
Re: Extending Multiple Metaclasses
« Reply #1 on: August 12, 2020, 10:25:00 am »
No, you're not Jayson!
I asked essentially the same question last week. Metatypes - multiple inheritance precedence order?
Hopefully, some Sparxin will answer.  I put in a support request, have you.  If not, do it.  That way you get a formal response.
Jayson
« Reply #2 on: August 12, 2020, 01:13:35 pm »
So in essence we have zero idea which properties take precedence? It just seems "weird with wheels" to me!
Thanks yet again Paolo.  :)
« Reply #3 on: August 12, 2020, 01:38:11 pm »
When your stereotype is relevant to multiple different element types. eg. it applies to both Association and Class.
There's no ambiguity or conflict in the above scenario, the properties that apply are the ones that relate to the metaclass that the stereotype is being created as an extension of.
I asked essentially the same question last week. Metatypes - multiple inheritance precedence order?\
Have I misunderstood your question? Precedence of multiple occurences of an extension within an inheritance hierarchy seems unrelated to having more than one available metatype.
Jayson
« Reply #4 on: August 12, 2020, 04:39:02 pm »
Hey Eve
Thanks for the reply.
However I am afraid that I am being particularly thick, cos I still don't get it.
So will try to clarify my stupidity for you.
1. If I create a stereotype that extends an Association MetaClass, Class MetaClass & an Activity Metaclass what does that even look like?
Is it a connector? Is it an element? Or some freaky combination of the two.
2. Under this scenario, both Activity and Class have a Default Diagram Type property.
If I make an instance of this stereotype composite, which Metaclass' Default Diagram Property determines which type of diagram to create.
Cheers
Jays :-)
Modesto Vega
« Reply #5 on: August 12, 2020, 05:42:04 pm »
I am not sure I understood the "problem" but, just in case, you do not create 1 stereotype to extend 3 metaclasses. If you need to extend 3 metaclasses, you create 3 stereotypes each one extending a different metaclass.
By the way, connectors are specialised elements. The fact that Sparx chose to implement them differently is most likely an accident of history.
Jayson
« Reply #6 on: August 12, 2020, 05:54:30 pm »
"If you need to extend 3 metaclasses, you create 3 stereotypes each one extending a different metaclass."
This makes 100% sense to me. However, if you look at the profile helpers it will allow me to add any number of metaclasses in the extensions box.
I am assuming that they have done this for some reason, but I will be damned if I can figure it out.
Cheers :-)
Modesto Vega
« Reply #7 on: August 12, 2020, 06:02:08 pm »
Could you please we more specific? Which one of the 3 profile helpers are you referring to - please see https://sparxsystems.com/enterprise_architect_user_guide/15.0/modeling/using_the_profile_helpers.html?
The reasons will be different for each profile helper.
Jayson
« Reply #8 on: August 12, 2020, 06:42:14 pm »
Heyo
I am talking about the "Add Stereotype" profile helper.
If you fire that up, it immediately asks you to specify:
1. Name of the stereotype.
2. Extensions (which are the metaclasses).
I can select as many metaclasses as I want to add here and it will let me.
Furthermore, it will allow me to set metaclass properties for each of them.
Cheers :-)
Modesto Vega
« Reply #9 on: August 12, 2020, 07:40:50 pm »
The stereotype helper "helps" to create stereotype profile. It does not extend any metaclasses instead it just places the metaclasses to be extended on a (stereotype) profile package, it is up to the end-user to extend the metaclasses. I don't see a problem with this.
« Reply #10 on: August 12, 2020, 08:01:50 pm »
You can indeed create a single stereotype that extends multiple meta-classes.
For example myStereotype extending both Class as UseCase
I don't think there's a conflict here. All properties you set on the Class metatype are used when you create this stereotype on a class basetype.
The properties you set on the Usecase metatype are used when you create this stereotype on a UseCase basetype.
It's not how I do it usually, but it works.
I usually create separate stereotypes for each different metatype (myClassStereotype and myUseCaseStereotype) to avoid confusion.
« Reply #11 on: August 12, 2020, 10:02:17 pm »
For example, myStereotype extending both Class and UseCase
I don't think there's a conflict here. All properties you set on the Class metatype are used when you create this stereotype on a class base-type.
The properties you set on the Usecase metatype are used when you create this stereotype on a UseCase base-type.
As Geert says, it's not how one normally wants to do it, but it works.
There's the perennial Association vs Association Class problem and we think we'll need a "DB SChema" metatype for both Classes and Packages - since we will want to group DB items by their schema into folders, but also have Schemas as first-class items themselves.
Modesto Vega
« Reply #12 on: August 13, 2020, 12:29:55 am »
[SNIP]
This has been my point all the way through.
[SNIP]
There is one scenario, which I cannot remember, in which some of the properties of the extending stereotype are applied to the metaclass. In this case, if you have 2 stereotypes extending the same metaclass one could/would overwrite the properties of the other.
