Author Topic: Relation matrix using relations stereotype  (Read 2594 times)
pgoes
« on: August 20, 2020, 11:42:42 pm »
Hi all,
I'm trying to use the relationshipmatrix to show and edit the relations between requirements and blocks in SysML 1.5.
Between the requirement and the blocks is a dependency relation with a stereotype of SysML1.5:Satisfy.
In the relationship matrix I select the requirements as source and the blocks as Target (block is subtype of class).
As Link type I select dependency.
I see the satisfy relations, so voor showing the relations the matrix is useable.
BUT when I add a new relation, the new created releation is of type normal dependency and not a dependency with stereotype of SysML1.5:Satisfy.
Herefore the relationshipmatrix is not usable to quickly add mass numbers of requirements to blocks using the matrix.
Is there a way to setup the relationshipmatrix so the newly created relation has the correct stereotype (in my case SysML1.5:Satisfy)?
Re: Relation matrix using relations stereotype
« Reply #1 on: August 21, 2020, 07:42:45 am »
Select "Satisfy" as the link type
« Last Edit: August 21, 2020, 07:47:13 am by KP »
