Author Topic: Conveyed Items: Different positions for GetAt(i) and Delete(i)  (Read 7583 times)
Viking
for (short i = (short)(Conn.ConveyedItems.Count - 1); i >= 0; i--)
  ConvItem = Conn.ConveyedItems.GetAt(i);
  if (ConvItem.ElementGUID == Elem.ElementGUID) {
    Conn.ConveyedItems.DeleteAt(i,true); // same problem with false
Conn.Update();
If I run this code, it does not delete ConvItem. It deletes another item in the collection. It only happens if ConveyedItems > 1. If there is only 1 item, everything is fine.
I never had problemes with collections before. I tried a lot of alternatives. That's why and because Geert Bellekens recommends it I report it as a bug.
See also https://www.sparxsystems.com/forums/smf/index.php/topic,44835.msg263969.html#msg263969
Re: Conveyed Items: Different positions for GetAt(i) and Delete(i)
« Reply #1 on: August 22, 2020, 04:42:14 am »
A bug is not reported here but with the bug report in the Support section below.
Viking
« Reply #2 on: August 22, 2020, 04:44:21 am »
Conn.ConveyedItems.DeleteAt(i + 1,true);
This works. Maybe there is a rule, so that I can use it as an intermediate solution.
Viking
« Reply #3 on: August 22, 2020, 04:46:48 am »
Many thanks @qwerty. I did not know. This section is called "Bugs and Issues" ...
I follow your recommendation :)
« Reply #4 on: August 22, 2020, 05:55:43 am »
You're not the first one being mislead ;-)
« Reply #5 on: August 22, 2020, 02:44:24 pm »
You would get an index out of bounds if you tried that on the last item of the collection wouldn't you?
Viking
« Reply #6 on: August 23, 2020, 08:21:29 pm »
That's true, Geert. The solution is much easier.
I report it in in the initial thread https://www.sparxsystems.com/forums/smf/index.php/topic,44835.0.html.
