Author Topic: Using not corresponding version of Interop.EA  (Read 4303 times)
Viking
« on: August 24, 2020, 12:43:34 am »
I identified a bug in Interop.EA recently. That’s why I would like to know:
(1)   I am using an older version of EA. Is it possible that the bug is gone in a newer version of EA or Interop.EA
(2)   Can Interop.EA.dll be downloaded separately?
(3)   If I understood Interop.EA correctly, there shouldn’t be a problem using another version of Interop.EA in EA. The concepts stay the same. Am I wrong?
Re: Using not corresponding version of Interop.EA
« Reply #1 on: August 24, 2020, 10:12:20 am »
Interop.EA.dll contains no behavior other than wrapping the COM api. There is no separate download of it.
If you have a newer version than EA it will allow compiling code that will break if new functions are called.
If you have an older version than EA, newer functions won't be available.
« Reply #2 on: August 24, 2020, 03:18:39 pm »
Yes, it's possible it's fixed in a newer version of EA, but as Eve indicated, you'll have to download and install that version of EA.
Viking
« Reply #3 on: August 24, 2020, 06:55:38 pm »
Understood.
Thank you.
