Author Topic: Where can I see the GUID of an element in EA 15.1?  (Read 8471 times)
jumbie
« on: August 30, 2020, 08:02:28 am »
I installed 15.1 and I don't see the GUID anywhere as an element property in the Browser, in older versions I saw it somewhere.
Where can I see the GUID of an element?
(I need to see it for checking in the outside program)
Richard Freggi
Re: Where can I see the GUID of an element in EA 15.1?
« Reply #1 on: August 30, 2020, 12:37:38 pm »
In the properties window, Project section
« Reply #2 on: August 30, 2020, 08:42:02 pm »
You can also copy the guid of each element from the project browser:
Right click | Copy / Paste | Copy Node GUID to Clipboard
jumbie
« Reply #3 on: August 30, 2020, 11:49:48 pm »
OK, but where can I invoke this Property window in 15.1?
At previous versions it was simple.
jumbie
« Reply #4 on: August 30, 2020, 11:50:26 pm »
Thanks, it works  :)
« Reply #5 on: August 31, 2020, 02:13:11 am »
Yes, a PITA. Type "proper" in the Search tab of the EA-menu top left. "Editors" will show. Select that and there you find the Properties. Simple, isn't it? At least if you're from planet Sparx.
jumbie
« Reply #6 on: August 31, 2020, 07:26:56 am »
OK, thanks,
I see it.  :)
