Author Topic: Generate sg-files for all diagrams  (Read 2293 times)
Tilo
« on: September 04, 2020, 04:19:37 pm »
Hello
I use EA 15.1. I want to export all diagrams to svg-files. The file name of a diagram should be the GUID.
The files should be used in another web-based application.
Unfortunately EA seems to support only "windows" emf vector format.
There is a svg plugin but I have no idea how to automate it to export around 1500 diagrams. The next problem is that the web-bases application is not able to print those correct.
At the moment I use the following solution:
A little VB Script loops through the project and creates a PDF of every diagram.
After that a batch-file uses inkscape to convert to PDF to SVG.
Before I used EA 13. With the older version everything was fine. With EA 15 something happened to the fonts. When I use the solution above single letters are missing in labels of the created SVG (They are still in the PDF).
inkscape seems not able the files correct anymore. When I configure inkscape to use the external "poppler" converter instead of the standard converter ths labes are fine again.
Thew problem with this solution is that the print tool of the web based application isn't able to handle the SVGs anymore. All labes are moved into a single line at the top of the diagram.
I also tried to export diagrams to emf and convert them the svg using inkscape. Inkscape isn't able to handle the emf files correct. Only labels are on the page. Symbol, lines, etc. have an offset, they are not placed at the correct postion. So far I only found paint which is able to handle the file correct.
Has anybody a solution how to export all diagrams into working and correct svg-files?
Thank you very much.
