Author Topic: Is there any way to have navigation cells pop-ups in HTML export?  (Read 3537 times)
Pino
« on: September 07, 2020, 09:57:21 pm »
Hi all,
Navigation cells are nice, but I really need to have them behave in HTML as they behave in EA: is there any way to achieve that?
Pino
Re: Is there any way to have navigation cells pop-ups in HTML export?
« Reply #1 on: September 07, 2020, 10:50:09 pm »
Pino,
What part of the behavior are you talking about?
Pino
« Reply #2 on: September 07, 2020, 11:48:57 pm »
Hi Geert,
I', referring at the way it works in EA: when you click on the navigation cell the referred content is presented as a pop-up, so you can use this as a quick look to a different diagram (an ArchiMate legend in my case). The HTML report works differently: one clicks on the cell and the frame is fully replaced by the content pointed at by the navigation cell, which is not what I need. The way it works in EA is just perfect, if only it could work the same way in the generated HTML.
~Pino
« Reply #3 on: September 07, 2020, 11:52:42 pm »
If you are into web-development, you can take a look at the CSS templates for the HTML export.
Not my cup of tea I'm afraid.
Pino
« Reply #4 on: September 07, 2020, 11:57:28 pm »
Hi Geert,
I'm not into web stuff either, which is why I'm asking here  :)
This is the behaviour in EA that I'd like to have in the generated HTML as well: https://i.gyazo.com/7116051658a3d3fe61568211b9c8cb14.mp4
~Pino
Sunshine
  • Its the results that count
« Reply #5 on: September 08, 2020, 08:42:57 am »
Guess it is possible using javascript embedded in the HTML. However if that is beyond your skill set then perhaps put a feature request in to Sparx for the HTML generation or alternatively ask for it in WebEA or Prolaborate.
Happy to help
