Author Topic: Missing toolbox entry of UML Profile after update to EA15.1  (Read 5284 times)
mapa
« on: September 11, 2020, 06:25:44 pm »
- I updated EA from EA12 to EA15 (Build 1529).
- The EA model (using cloud server) has a imported UML profile (resources window).
- In EA12 the toolbox has a entry for this imported UML profile.
- In EA15 I don't found this entry either in the toolbox or in the toolbox visibility.
Did I unchecked any checkbox or is it a bug?
Re: Missing toolbox entry of UML Profile after update to EA15.1
« Reply #1 on: September 11, 2020, 06:30:30 pm »
Probably because you selected a perspective that doesn't include your toolbox.
Go to the top right and select "All" for perspective, and then try again.
mapa
« Reply #2 on: September 11, 2020, 07:56:26 pm »
Perspective "All" was already selected.
Markus
« Reply #3 on: September 11, 2020, 08:02:30 pm »
Wasn't there a recent Paolo-rant that "All is not All"?
« Reply #4 on: September 11, 2020, 08:09:08 pm »
Markus
There used to be a bug where All didn't really include All.
Have you tried selecting "All specialized"
mapa
« Reply #5 on: September 15, 2020, 06:53:43 am »
Also the perspective "All specialized" didn't work for me.
Now I create an empty EAP model and import the UML profile with the EA15.1.
Result: The UML profile is not visible in the toolbox.
Perhaps this feature is no longer supported in the new version?
Markus
used UML profile content:
<UMLProfile profiletype="uml2">
   <Documentation id="58566F4A-C" name="CSS_TestCases" version="1.0" notes="CSS_TestCases"/>
   <Content>
      <Stereotypes>
         <Stereotype name="device-testcase" notes="" cx="0" cy="0" bgcolor="-1" fontcolor="-1" bordercolor="-1" borderwidth="-1" hideicon="0">
            <AppliesTo>
               <Apply type="UseCase"/>
            </AppliesTo>
         </Stereotype>
         <Stereotype name="hw-sw-it-canoe" notes="&lt;b&gt;Test Objective:&lt;/b&gt;&#xA;[Beschreibung (Ziel; Zweck)]&#xA;&lt;i&gt;Hier den Inhalt des Tests beschreiben, ggf. Verweis auf Referenzdokumente, Verhaltensbeschreibung&lt;/i&gt;&#xA;&lt;i&gt;Startbedigungen, Endbedingunen, Parameterlisten&lt;/i&gt;&#xA;&lt;i&gt;die ACC des Features ber�cksichtigen&lt;/i&gt;&#xA;&lt;i&gt;&#xA;&lt;/i&gt;&lt;b&gt;Expected Result:&lt;/b&gt;&#xA;[Erwartetes Ergebnis:]&#xA;&#xA;&lt;b&gt;Execution condition:&lt;/b&gt;&#xA;[Ausf�hrungsbedingungen:]&#xA;&#xA;&lt;b&gt;Precondition:&lt;/b&gt;&#xA;[Vorbedingungen:]&#xA;&lt;i&gt;Was wird als Vorbedingung zur Testausf�hrung ben�tigt?&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Postcondition:&lt;/b&gt;&#xA;[Abschlussbedingungen:]&#xA;&lt;i&gt;Was muss nach der Durchf�hrung gemacht werden, &quot;completition&quot;?&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Referenced documents:&lt;/b&gt;&#xA;[referenzierte Dokumente:]&#xA;&#xA;&lt;i&gt;-Parameterlisten&lt;/i&gt;&#xA;&lt;i&gt;-Ablaufdiagramme&lt;/i&gt;&#xA;&lt;i&gt;-...&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Checklist for relevant Info:&lt;/b&gt;&#xA;&lt;b&gt;Device: &lt;/b&gt;&lt;i&gt;Name&lt;/i&gt;&#xA;&lt;b&gt;Node ID:&lt;/b&gt;&#xA;&lt;b&gt;Messages:&lt;/b&gt;&#xA;&lt;b&gt;Message IDs:&lt;/b&gt;&#xA;&lt;b&gt;Errors:&lt;/b&gt;&#xA;&lt;b&gt;Essential IO Names from Domain Model:&lt;/b&gt;&#xA;&lt;i&gt;z.B. heatdemand oder fuelwalve, purge, prepurge...&lt;/i&gt;&#xA;Canopen Objects/GPIOS Names:&#xA;Canopen SRDO configuration:&#xA;&lt;i&gt;Beispiel: &lt;/i&gt;&#xA;&lt;b&gt;Timings:&lt;/b&gt;&#xA;&lt;i&gt;Purge: &lt;/i&gt;&#xA;min: &#xA;max:&#xA;tolerance:&#xA;&#xA;&#xA;&lt;b&gt;Path to executables Vtestudio/Canoe :&lt;/b&gt;" cx="0" cy="0" bgcolor="-1" fontcolor="-1" bordercolor="-1" borderwidth="-1" hideicon="0">
            <AppliesTo>
            </AppliesTo>
         </Stereotype>
         <Stereotype name="hw-sw-it-manual" notes="&lt;b&gt;Vorschlag (to be discussed)&lt;/b&gt;&#xA;&lt;b&gt;&#xA;&lt;/b&gt;&lt;b&gt;Test Objective:&lt;/b&gt;&#xA;[Beschreibung (Ziel; Zweck)]&#xA;&lt;i&gt;Hier den Inhalt des Tests beschreiben, ggf. Verweis auf Referenzdokumente, Verhaltensbeschreibung&lt;/i&gt;&#xA;&lt;i&gt;Startbedigungen, Endbedingunen, Parameterlisten&lt;/i&gt;&#xA;&lt;i&gt;die ACC des Features ber�cksichtigen&lt;/i&gt;&#xA;&lt;i&gt;&#xA;&lt;/i&gt;&lt;b&gt;Expected Result:&lt;/b&gt;&#xA;[Erwartetes Ergebnis:]&#xA;&#xA;&lt;b&gt;Execution condition:&lt;/b&gt;&#xA;[Ausf�hrungsbedingungen:]&#xA;&#xA;&lt;b&gt;Precondition:&lt;/b&gt;&#xA;[Vorbedingungen:]&#xA;&lt;i&gt;Was wird als Vorbedingung zur Testausf�hrung ben�tigt?&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Postcondition:&lt;/b&gt;&#xA;[Abschlussbedingungen:]&#xA;&lt;i&gt;Was muss nach der Durchf�hrung gemacht werden, &quot;completition&quot;?&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Referenced documents:&lt;/b&gt;&#xA;[referenzierte Dokumente:]&#xA;&#xA;&lt;i&gt;-Parameterlisten&lt;/i&gt;&#xA;&lt;i&gt;-Ablaufdiagramme&lt;/i&gt;&#xA;&lt;i&gt;-...&lt;/i&gt;&#xA;&#xA;&#xA;&lt;b&gt;Checklist for relevant Info:&lt;/b&gt;&#xA;&lt;b&gt;Device: &lt;/b&gt;&lt;i&gt;Name&lt;/i&gt;&#xA;&lt;b&gt;Node ID:&lt;/b&gt;&#xA;&lt;b&gt;Messages:&lt;/b&gt;&#xA;&lt;b&gt;Message IDs:&lt;/b&gt;&#xA;&lt;b&gt;Errors:&lt;/b&gt;&#xA;&lt;b&gt;Essential IO Names from Domain Model:&lt;/b&gt;&#xA;&lt;i&gt;z.B. heatdemand oder fuelwalve, purge, prepurge...&lt;/i&gt;&#xA;Canopen Objects/GPIOS Names:&#xA;Canopen SRDO configuration:&#xA;&lt;i&gt;Beispiel: &lt;/i&gt;&#xA;&lt;b&gt;Timings:&lt;/b&gt;&#xA;&lt;i&gt;Purge: &lt;/i&gt;&#xA;min: &#xA;max:&#xA;tolerance:&#xA;&#xA;&#xA;&lt;b&gt;Path to executables:&lt;/b&gt;&#xA;" cx="0" cy="0" bgcolor="-1" fontcolor="-1" bordercolor="-1" borderwidth="-1" hideicon="0">
            <AppliesTo>
            </AppliesTo>
         </Stereotype>
         <Stereotype name="hw-sw-it-python" notes="&lt;b&gt;Vorschlag (to be discussed)&lt;/b&gt;&#xA;&lt;b&gt;&#xA;&lt;/b&gt;&lt;b&gt;Test Objective:&lt;/b&gt;&#xA;[Beschreibung (Ziel; Zweck)]&#xA;&lt;i&gt;Hier den Inhalt des Tests beschreiben, ggf. Verweis auf Referenzdokumente, Verhaltensbeschreibung&lt;/i&gt;&#xA;&lt;i&gt;Startbedigungen, Endbedingunen, Parameterlisten&lt;/i&gt;&#xA;&lt;i&gt;die ACC des Features ber�cksichtigen&lt;/i&gt;&#xA;&lt;i&gt;&#xA;&lt;/i&gt;&lt;b&gt;Expected Result:&lt;/b&gt;&#xA;[Erwartetes Ergebnis:]&#xA;&#xA;&lt;b&gt;Execution condition:&lt;/b&gt;&#xA;[Ausf�hrungsbedingungen:]&#xA;&#xA;&lt;b&gt;Precondition:&lt;/b&gt;&#xA;[Vorbedingungen:]&#xA;&lt;i&gt;Was wird als Vorbedingung zur Testausf�hrung ben�tigt?&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Postcondition:&lt;/b&gt;&#xA;[Abschlussbedingungen:]&#xA;&lt;i&gt;Was muss nach der Durchf�hrung gemacht werden, &quot;completition&quot;?&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Referenced documents:&lt;/b&gt;&#xA;[referenzierte Dokumente:]&#xA;&#xA;&lt;i&gt;-Parameterlisten&lt;/i&gt;&#xA;&lt;i&gt;-Ablaufdiagramme&lt;/i&gt;&#xA;&lt;i&gt;-...&lt;/i&gt;&#xA;&#xA;&#xA;&lt;b&gt;Checklist for relevant Info:&lt;/b&gt;&#xA;&lt;b&gt;Device: &lt;/b&gt;&lt;i&gt;Name&lt;/i&gt;&#xA;&lt;b&gt;Node ID:&lt;/b&gt;&#xA;&lt;b&gt;Messages:&lt;/b&gt;&#xA;&lt;b&gt;Message IDs:&lt;/b&gt;&#xA;&lt;b&gt;Errors:&lt;/b&gt;&#xA;&lt;b&gt;Essential IO Names from Domain Model:&lt;/b&gt;&#xA;&lt;i&gt;z.B. heatdemand oder fuelwalve, purge, prepurge...&lt;/i&gt;&#xA;Canopen Objects/GPIOS Names:&#xA;Canopen SRDO configuration:&#xA;&lt;i&gt;Beispiel: &lt;/i&gt;&#xA;&lt;b&gt;Timings:&lt;/b&gt;&#xA;&lt;i&gt;Purge: &lt;/i&gt;&#xA;min: &#xA;max:&#xA;tolerance:&#xA;&#xA;&#xA;&lt;b&gt;Path to executables:&lt;/b&gt;" cx="0" cy="0" bgcolor="-1" fontcolor="-1" bordercolor="-1" borderwidth="-1" hideicon="0">
            <AppliesTo>
            </AppliesTo>
         </Stereotype>
         <Stereotype name="hw-test" notes="&lt;b&gt;Vorschlag (to be discussed)&lt;/b&gt;&#xA;&lt;b&gt;&#xA;&lt;/b&gt;&lt;b&gt;Test Objective:&lt;/b&gt;&#xA;[Beschreibung (Ziel; Zweck)]&#xA;&lt;i&gt;Hier den Inhalt des Tests beschreiben, ggf. Verweis auf Referenzdokumente, Verhaltensbeschreibung&lt;/i&gt;&#xA;&lt;i&gt;Startbedigungen, Endbedingunen, Parameterlisten&lt;/i&gt;&#xA;&lt;i&gt;die ACC des Features ber�cksichtigen&lt;/i&gt;&#xA;&lt;i&gt;&#xA;&lt;/i&gt;&lt;b&gt;Expected Result:&lt;/b&gt;&#xA;[Erwartetes Ergebnis:]&#xA;&#xA;&lt;b&gt;Execution condition:&lt;/b&gt;&#xA;[Ausf�hrungsbedingungen:]&#xA;&#xA;&lt;b&gt;Precondition:&lt;/b&gt;&#xA;[Vorbedingungen:]&#xA;&lt;i&gt;Was wird als Vorbedingung zur Testausf�hrung ben�tigt?&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Postcondition:&lt;/b&gt;&#xA;[Abschlussbedingungen:]&#xA;&lt;i&gt;Was muss nach der Durchf�hrung gemacht werden, &quot;completition&quot;?&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Referenced documents:&lt;/b&gt;&#xA;[referenzierte Dokumente:]&#xA;&#xA;&lt;i&gt;-Parameterlisten&lt;/i&gt;&#xA;&lt;i&gt;-Ablaufdiagramme&lt;/i&gt;&#xA;&lt;i&gt;-...&lt;/i&gt;&#xA;&#xA;&#xA;&lt;b&gt;Checklist for relevant Info:&lt;/b&gt;&#xA;&lt;b&gt;Device: &lt;/b&gt;&lt;i&gt;Name&lt;/i&gt;&#xA;&lt;b&gt;Node ID:&lt;/b&gt;&#xA;&lt;b&gt;Messages:&lt;/b&gt;&#xA;&lt;b&gt;Message IDs:&lt;/b&gt;&#xA;&lt;b&gt;Errors:&lt;/b&gt;&#xA;&lt;b&gt;Essential IO Names from Domain Model:&lt;/b&gt;&#xA;&lt;i&gt;z.B. heatdemand oder fuelwalve, purge, prepurge...&lt;/i&gt;&#xA;Canopen Objects/GPIOS Names:&#xA;Canopen SRDO configuration:&#xA;&lt;i&gt;Beispiel: &lt;/i&gt;&#xA;&lt;b&gt;Timings:&lt;/b&gt;&#xA;&lt;i&gt;Purge: &lt;/i&gt;&#xA;min: &#xA;max:&#xA;tolerance:&#xA;&#xA;&#xA;&lt;b&gt;Path to executables:&lt;/b&gt;&#xA;" cx="0" cy="0" bgcolor="-1" fontcolor="-1" bordercolor="-1" borderwidth="-1" hideicon="0">
            <AppliesTo>
            </AppliesTo>
         </Stereotype>
         <Stereotype name="manual-verification" notes="Link to document:&#xA;&amp;lt;insert here&amp;gt;" cx="0" cy="0" bgcolor="-1" fontcolor="-1" bordercolor="-1" borderwidth="-1" hideicon="0">
            <AppliesTo>
            </AppliesTo>
         </Stereotype>
         <Stereotype name="mech-test" notes="&lt;b&gt;Vorschlag (to be discussed)&lt;/b&gt;&#xA;&lt;b&gt;&#xA;&lt;/b&gt;&lt;b&gt;Test Objective:&lt;/b&gt;&#xA;[Beschreibung (Ziel; Zweck)]&#xA;&lt;i&gt;Hier den Inhalt des Tests beschreiben, ggf. Verweis auf Referenzdokumente, Verhaltensbeschreibung&lt;/i&gt;&#xA;&lt;i&gt;Startbedigungen, Endbedingunen, Parameterlisten&lt;/i&gt;&#xA;&lt;i&gt;die ACC des Features ber�cksichtigen&lt;/i&gt;&#xA;&lt;i&gt;&#xA;&lt;/i&gt;&lt;b&gt;Expected Result:&lt;/b&gt;&#xA;[Erwartetes Ergebnis:]&#xA;&#xA;&lt;b&gt;Execution condition:&lt;/b&gt;&#xA;[Ausf�hrungsbedingungen:]&#xA;&#xA;&lt;b&gt;Precondition:&lt;/b&gt;&#xA;[Vorbedingungen:]&#xA;&lt;i&gt;Was wird als Vorbedingung zur Testausf�hrung ben�tigt?&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Postcondition:&lt;/b&gt;&#xA;[Abschlussbedingungen:]&#xA;&lt;i&gt;Was muss nach der Durchf�hrung gemacht werden, &quot;completition&quot;?&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Referenced documents:&lt;/b&gt;&#xA;[referenzierte Dokumente:]&#xA;&#xA;&lt;i&gt;-Parameterlisten&lt;/i&gt;&#xA;&lt;i&gt;-Ablaufdiagramme&lt;/i&gt;&#xA;&lt;i&gt;-...&lt;/i&gt;&#xA;&#xA;&#xA;&lt;b&gt;Checklist for relevant Info:&lt;/b&gt;&#xA;&lt;b&gt;Device: &lt;/b&gt;&lt;i&gt;Name&lt;/i&gt;&#xA;&lt;b&gt;Node ID:&lt;/b&gt;&#xA;&lt;b&gt;Messages:&lt;/b&gt;&#xA;&lt;b&gt;Message IDs:&lt;/b&gt;&#xA;&lt;b&gt;Errors:&lt;/b&gt;&#xA;&lt;b&gt;Essential IO Names from Domain Model:&lt;/b&gt;&#xA;&lt;i&gt;z.B. heatdemand oder fuelwalve, purge, prepurge...&lt;/i&gt;&#xA;Canopen Objects/GPIOS Names:&#xA;Canopen SRDO configuration:&#xA;&lt;i&gt;Beispiel: &lt;/i&gt;&#xA;&lt;b&gt;Timings:&lt;/b&gt;&#xA;&lt;i&gt;Purge: &lt;/i&gt;&#xA;min: &#xA;max:&#xA;tolerance:&#xA;&#xA;&#xA;&lt;b&gt;Path to executables:&lt;/b&gt;&#xA;" cx="0" cy="0" bgcolor="-1" fontcolor="-1" bordercolor="-1" borderwidth="-1" hideicon="0">
            <AppliesTo>
            </AppliesTo>
         </Stereotype>
         <Stereotype name="sw-sw-it" notes="&lt;b&gt;Test Objective:&lt;/b&gt;&#xA;[Beschreibung (Ziel; Zweck)]&#xA;&lt;i&gt;Hier den Inhalt des Tests beschreiben, ggf. Verweis auf Referenzdokumente, Verhaltensbeschreibung&lt;/i&gt;&#xA;&lt;i&gt;Startbedigungen, Endbedingunen, Parameterlisten&lt;/i&gt;&#xA;&lt;i&gt;die ACC des Features ber�cksichtigen&lt;/i&gt;&#xA;&lt;i&gt;&#xA;&lt;/i&gt;&lt;b&gt;Expected Result:&lt;/b&gt;&#xA;[Erwartetes Ergebnis:]&#xA;&#xA;&lt;b&gt;Execution condition:&lt;/b&gt;&#xA;[Ausf�hrungsbedingungen:]&#xA;&#xA;&lt;b&gt;Precondition:&lt;/b&gt;&#xA;[Vorbedingungen:]&#xA;&lt;i&gt;Was wird als Vorbedingung zur Testausf�hrung ben�tigt?&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Postcondition:&lt;/b&gt;&#xA;[Abschlussbedingungen:]&#xA;&lt;i&gt;Was muss nach der Durchf�hrung gemacht werden, &quot;completition&quot;?&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Referenced documents:&lt;/b&gt;&#xA;[referenzierte Dokumente:]&#xA;&#xA;&lt;i&gt;-Parameterlisten&lt;/i&gt;&#xA;&lt;i&gt;-Ablaufdiagramme&lt;/i&gt;&#xA;&lt;i&gt;-...&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Checklist for relevant Info:&lt;/b&gt;&#xA;&lt;b&gt;Device: &lt;/b&gt;&lt;i&gt;Name&lt;/i&gt;&#xA;&lt;b&gt;Node ID:&lt;/b&gt;&#xA;&lt;b&gt;Messages:&lt;/b&gt;&#xA;&lt;b&gt;Message IDs:&lt;/b&gt;&#xA;&lt;b&gt;Errors:&lt;/b&gt;&#xA;&lt;b&gt;Essential IO Names from Domain Model:&lt;/b&gt;&#xA;&lt;i&gt;z.B. heatdemand oder fuelwalve, purge, prepurge...&lt;/i&gt;&#xA;Canopen Objects/GPIOS Names:&#xA;Canopen SRDO configuration:&#xA;&lt;i&gt;Beispiel: &lt;/i&gt;&#xA;&lt;b&gt;Timings:&lt;/b&gt;&#xA;&lt;i&gt;Purge: &lt;/i&gt;&#xA;min: &#xA;max:&#xA;tolerance:&#xA;&#xA;&#xA;&lt;b&gt;Path to executables:&lt;/b&gt;&#xA;" cx="0" cy="0" bgcolor="-1" fontcolor="-1" bordercolor="-1" borderwidth="-1" hideicon="0">
            <AppliesTo>
            </AppliesTo>
         </Stereotype>
         <Stereotype name="system-testcase" notes="" cx="0" cy="0" bgcolor="-1" fontcolor="-1" bordercolor="-1" borderwidth="-1" hideicon="0">
            <AppliesTo>
            </AppliesTo>
         </Stereotype>
         <Stereotype name="unit-test" notes="&lt;b&gt;Test Objective:&lt;/b&gt;&#xA;[Beschreibung (Ziel; Zweck)]&#xA;&lt;i&gt;Hier den Inhalt des Tests beschreiben, ggf. Verweis auf Referenzdokumente, Verhaltensbeschreibung&lt;/i&gt;&#xA;&lt;i&gt;Startbedigungen, Endbedingunen, Parameterlisten&lt;/i&gt;&#xA;&lt;i&gt;die ACC des Features ber�cksichtigen&lt;/i&gt;&#xA;&lt;i&gt;&#xA;&lt;/i&gt;&lt;b&gt;Expected Result:&lt;/b&gt;&#xA;[Erwartetes Ergebnis:]&#xA;&#xA;&lt;b&gt;Execution condition:&lt;/b&gt;&#xA;[Ausf�hrungsbedingungen:]&#xA;&#xA;&lt;b&gt;Precondition:&lt;/b&gt;&#xA;[Vorbedingungen:]&#xA;&lt;i&gt;Was wird als Vorbedingung zur Testausf�hrung ben�tigt?&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Postcondition:&lt;/b&gt;&#xA;[Abschlussbedingungen:]&#xA;&lt;i&gt;Was muss nach der Durchf�hrung gemacht werden, &quot;completition&quot;?&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Referenced documents:&lt;/b&gt;&#xA;[referenzierte Dokumente:]&#xA;&#xA;&lt;i&gt;-Parameterlisten&lt;/i&gt;&#xA;&lt;i&gt;-Ablaufdiagramme&lt;/i&gt;&#xA;&lt;i&gt;-...&lt;/i&gt;&#xA;&#xA;&lt;b&gt;Checklist for relevant Info:&lt;/b&gt;&#xA;&lt;b&gt;Device: &lt;/b&gt;&lt;i&gt;Name&lt;/i&gt;&#xA;&lt;b&gt;Node ID:&lt;/b&gt;&#xA;&lt;b&gt;Messages:&lt;/b&gt;&#xA;&lt;b&gt;Message IDs:&lt;/b&gt;&#xA;&lt;b&gt;Errors:&lt;/b&gt;&#xA;&lt;b&gt;Essential IO Names from Domain Model:&lt;/b&gt;&#xA;&lt;i&gt;z.B. heatdemand oder fuelwalve, purge, prepurge...&lt;/i&gt;&#xA;Canopen Objects/GPIOS Names:&#xA;Canopen SRDO configuration:&#xA;&lt;i&gt;Beispiel: &lt;/i&gt;&#xA;&lt;b&gt;Timings:&lt;/b&gt;&#xA;&lt;i&gt;Purge: &lt;/i&gt;&#xA;min: &#xA;max:&#xA;tolerance:&#xA;&#xA;&#xA;&lt;b&gt;Path to executables:&lt;/b&gt;&#xA;" cx="0" cy="0" bgcolor="-1" fontcolor="-1" bordercolor="-1" borderwidth="-1" hideicon="0">
            <AppliesTo>
            </AppliesTo>
         </Stereotype>
      </Stereotypes>
      <TaggedValueTypes/>
      <ViewDefinitions/>
      <Metamodel/>
   </Content>
</UMLProfile>[/size][/font]
« Reply #6 on: September 15, 2020, 07:41:25 am »
When you import a profile you don't have any linkage to toolboxes. That exists only for a MDG. Importing this XML as profile shows well in the Resources/Profiles.
