Author Topic: DB Schema import radio buttons  (Read 9432 times)
Uffe
« on: September 17, 2020, 05:15:55 pm »
In 15.0.1512, if you fire up the DB schema import dialog there are two radio buttons in the lower right:
  • Synchronize existing classes
  • Import as New objects
When the dialog opens, neither is selected.
The normal way this works in any well-behaved Windows application is that the developer doesn't pick a default but requires the user to make a choice. But not in EA. You can run the dialog with neither button selected. Which behaviour you get is undefined.
Is this still the case in 15.2, can anyone check?
/Uffe
