Author Topic: Boundaries and Default Image: label visibility  (Read 4446 times)
Rik van der Schalie
« on: September 23, 2020, 06:24:41 pm »
when I assign an image to a boundary (by using "Select a Default image..." or "Select an Alternate Image..."(by the way, what is the difference?)), the name of the boundary is no longer displayed.
Is there a way to overcome this (other than to put a Text Element on the boundary)?
« Last Edit: September 23, 2020, 06:41:19 pm by rchalie »
Re: Boundaries and Default Image: label visibility
« Reply #1 on: September 23, 2020, 07:10:35 pm »
I think you're out of luck here. A crude work around could be to use the notes of the boundary for/instead of its name and place a note linked to the boundaries element feature on the diagram.
« Reply #2 on: September 24, 2020, 07:17:59 am »
Default image applies to all diagrams that element is used. (Which for boundaries should be one)
Alternate image only applies to the current diagram.
