Author Topic: Adding Flow Properties direction using VB Script  (Read 3790 times)
Deepu M
« on: September 29, 2020, 09:46:05 pm »
Iam trying to add an Interface Block for representing a data type for my port. As part adding direction of the data flow, I need to add a flow properties inside the interface block. When I type my port with this interface block , it will show the data type and the direction of the flow.
I trying to add this using VB Script using the following code and Iam not able to set the direction to the flow properties using the script
dim strDataFlowTypeName
strDataFlowTypeName = InputBox("Enter the Data flow type Name")
MsgBox CStr(thePackage.Elements.Count)
set dataFlowType = thePackage.Elements.AddNew(strDataFlowTypeName,"InterfaceBlock")
dataFlowType.Update()
if Not IsNull(dataFlowType) Then
Set dataFlowProperty = dataFlowType.Elements.AddNew(strDataFlowTypeName, "FlowProperty")
// Here I need to set the direction of the flow propery as "Out"
// Iam tried a lot to set that
dataFlowProperty.Update()
Any help to solve this will highly be appreciated
Best Regards
Deepu M
Re: Adding Flow Properties direction using VB Script
« Reply #1 on: September 29, 2020, 09:59:16 pm »
I guess you'll have to check where that property is stored in order to figure out how to set it.
I would start looking at
- t_object (the element)
- t_objecttproperties (tagged values on the element)
- t_xref (all kinds of stuff)
