Author Topic: Apply Stereotype  (Read 3998 times)
bctm
Apply Stereotype
« on: December 07, 2012, 03:02:17 am »
I'm creating with a C# AddIn a new element (UseCase) and want to apply a predefined stereotype with attached TaggedValues to this element.
Of course it isn't a problem to set the stereotype via Element.Stereotype = "", but this doesn't apply the stereotype to the UC-element. It just populates the stereotype field.
What can I do to get the TaggedValues and eventually the styles?
I'm using EA 8, I've seen that in the UserGuide for EA9 there is a "SynchProfile" method for the Repository object, but this method isn't available in EA8.
Thanks for your help.
Re: Apply Stereotype
« Reply #1 on: December 07, 2012, 04:30:59 am »
I guess you have to upgrade. It's (almost) impossible to create the tagged values for a certain MDG. I explained that in my Inside EA book pg. 35:
As mentioned above there’s some magic with GUIDs for tagged values that come from a MDG profile. These look exactly like ‘normal’ GUIDS:
{aaaaaaaa-aaaa-aaaa-bbbb-bbbbbbbbbbbb}
Here the a and b hex codes are not completely random. Only the b part is completely random, but the a part is a hash code computed individually per profile. The hash algorithm is internal to EA and unfortunately not known.
