Author Topic: Convert atomic Action to CallBehaviorAction  (Read 6033 times)
danny ocean
« on: October 06, 2020, 02:56:58 am »
I try to model the behavior of a system with SysML 1.4 in EA 13. In the process of modelling an Activity Diagram, I usually start with atomic Actions. As time goes by and the details of the system behavior get clearer, I would like to go deeper in the modelling and show details of some Actions in other Activity Diagrams. I don't know if there's a proper word for it - maybe call it layered activity diagrams.
If the atomic Action was a CallBehaviorAction connected to an Activity with a corresponding composite diagram, I could double-click (on the Action in the Activity Diagram) and open the more detailled Activity Diagram. However, I found no possibility to convert an atomic Action into a CallBehaviorAction. Is anyone aware of a solution or a hint?
Re: Convert atomic Action to CallBehaviorAction
« Reply #1 on: October 06, 2020, 03:26:39 am »
In version 15.2, select the action, select the "Action" tab in the properties, and change the "Kind".
https://imgur.com/LtXxvUZ
After you change the Kind, you have to close the action (or select something else) and re-open it again before the behavior tab shows up where you can select the behavior.
danny ocean
« Reply #2 on: October 06, 2020, 04:35:28 pm »
Thank you, Geert! In EA v13 the properties window looks slightly different, but I found it (Properties -> General -> Advanced -> kind). Thank you!
