Author Topic: Simulation of Activity Diagram not executing corre  (Read 4296 times)
exquisitus
« on: December 09, 2012, 08:26:40 am »
In an Activity diagram with object flow, the simulator does not execute correctly. It starts, and then ends without following the flow paths. If I remove the objects, having a diagram with only actions, it's working correctly. Is this by design, a bug or do I miss something? (EA 9.3 Prof evaluation). Any hint is highly appreciated.
Re: Simulation of Activity Diagram not executing c
« Reply #1 on: December 10, 2012, 08:36:16 am »
Object Flow isn't used at all in 9.3.
exquisitus
« Reply #2 on: December 11, 2012, 06:45:37 pm »
Hi Simon
Could you explain what you mean with 'Object Flow isn't used at all in 9.3. '? A answer like this does not help me much further.
« Reply #3 on: December 11, 2012, 06:59:17 pm »
I suspect it means that in EA version 9.3 the simulation engine doesn't take into account object flows, but only control flows.
And because Simon is so specific about the version I suspect also that that might be different in version 10.
