Author Topic: Decode BinContent in t_document  (Read 40647 times)
Viking
« on: October 09, 2020, 09:46:10 pm »
I am trying to read BinContent in t_document. I found this very useful answer from @qwerty: “It's a base64 encoded zip with a single file str.dat as contents.” in https://www.sparxsystems.com/forums/smf/index.php/topic,42555.msg252958.html#msg252958
I tried the code below. But FromBase64String throws the exception, that “The input is not a valid Base-64 string as it contains a non-base 64 character, more than two padding characters, or an illegal character among the padding characters.”
Could somebody tell me what’s wrong with the code, please? V.
String query = "SELECT BinContent from t_document where ElementID = 'TECHNOLOGY'";
List<Document> docs = XMLService.GetXMLasObjects<Document>(Sparx.Repository.SQLQuery(query));
foreach (Document aDoc in docs)
  Byte[] aBinContent = aDoc.BinContent;
  // Unzip
  using (var memoryStream = new MemoryStream(aBinContent))
    using (var archive = new ZipArchive(memoryStream, ZipArchiveMode.Read))
      foreach (var entry in archive.Entries)
        using (var stream = entry.Open())
        using (var reader = new StreamReader(stream))
          String unzippedData = reader.ReadToEnd();
  // Decode base64
  byte[] zipBytes = Convert.FromBase64String(unzippedData);
Re: Decode BinContent in t_document
« Reply #1 on: October 09, 2020, 09:58:15 pm »
What does the bincontent result actually show? First and last chars would be enough to see.
« Reply #2 on: October 09, 2020, 10:03:12 pm »
Yeah, I don't think it's the same base64 format used in other places.
That looks more like
Qk02AwAAAAAAADYAAAAoAAAAEAAAABAAAAABABgAAAAAAAADAADEDgAAxA4AAAAAAAAAAAAA
wMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDA
wMDAwMDAQEBAQEBAQEBAQEBAQEBAwMDATn6mwMDATn6mwMDAwMDAwMDAwMDAwMDApqamQEBA
The bincontent is some kind of hex format I think, it always starts with "0x"
0x504B0304140000000800AA713C47B1E305CA66D00000464...
I don't think I've already seen a solution on how to decode that format.
« Reply #3 on: October 09, 2020, 10:13:15 pm »
I got curious, and it's indeed a different encoding.
I was able to decode a bincontent string (of a small png image) into a file using https://tomeko.net/online_tools/hex_to_file.php?lang=en
The downloaded file was again the classifical .zip file with str.dat as content.
I'm not sure how this website does the conversion, but it seems rather trivial.
Viking
« Reply #4 on: October 09, 2020, 11:08:37 pm »
@qwerty, @Geert: I do not get the content mentioned in the thread. Mine starts with "<\0?\0x\0m\0l\0 \0v\0e\0r\0s\0i ...". That does not really look correct :-(
Normally I would prefere using Repository.Execute(). But it does not support reading data.
Viking
« Reply #5 on: October 09, 2020, 11:18:24 pm »
Could you share the code to get the HEX, please? I am not sure, if the sequence I implemented is correct.
« Reply #6 on: October 09, 2020, 11:49:38 pm »
I didn't use code to get the content, just copy paste from SQL server management studio
« Reply #7 on: October 10, 2020, 02:06:40 am »
That's some UTF8 text (...Vers...)
« Reply #8 on: October 10, 2020, 02:09:59 am »
Looks like TECHNOLOGY entries are plain UTF8 (or was it 16?) strings.
P.S. Could you help me with creating a TECHNOLOGY entry in t_document?
Viking
« Reply #9 on: October 12, 2020, 04:00:45 am »
I am afraid that Repository.SQLQuery does some conversion. If I directly access the database I see the expected data.
« Reply #10 on: October 12, 2020, 06:31:27 am »
Well, SQLQuery converts binary data to base64 as it creates an XML result  - and binary in an XML is not a good idea. So yes, a direct access will return the blob as it is.
Ian Mitchell
« Reply #11 on: February 22, 2024, 02:25:45 am »
I have tried to make this work, but when I try to open the ZipArchiveEntry for the str.dat file, I get an error: "A local file header is corrupt".
This may sugest that Sparx have done something else on top of the (ZIP + base64 encoding) which now seems to be normal for potentially large data fields like this.
The data I  am trying to extract is a simple test case:  the translation data for a single element, where I added the translation to the 'notes' translation tab via the UI.
Has anyone else had success in extracting this data?
@Sparx - are there any instructions anywhere which say how to acess this data? Maybe an API call?
www.eaDocX.com
www.theartfulmodeller.com
Ian Mitchell
« Reply #12 on: February 22, 2024, 02:32:09 am »
If anyone needs a test case, the data from EA was: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which was extracted using a simple bit of SQL to read the BinContent column of t_document.
The text should decode to something like:
Dit zijn enkele aantekeningen in het Nederlands, de secundaire taal van EA. Het vertalen gebeurt nog steeds handmatig.
(Apologies to native Dutch speakers: this is aGoogle translation.)
www.eaDocX.com
« Reply #13 on: February 22, 2024, 03:03:26 am »
Ian,
I'm pretty sure I saw some methods to get translations using the API
EA.Element.GetTXNote (string Code, long Flag) and the likes.
PS. the Dutch is pretty much OK, no apologies neede :)
johann
« Reply #14 on: February 22, 2024, 07:25:09 pm »
I hope this doesn't disclose a business secret:
Decode the BASE64 and replace the first two bytes (letters "SS") with the letters "PK" - now you have a valid PKZip archive format.
Extract the (single) entry "str.dat":
<?xml version="1.0" standalone="no" ?>
<translations><translation language="nl" nameLocked="0" aliasLocked="0" notesLocked="1" nameChecksum="0" aliasChecksum="0" notesChecksum="0" name="" alias="">Dit zijn enkele aantekeningen in het Nederlands, de secundaire taal van EA. Het vertalen gebeurt nog steeds handmatig.</translation></translations>
We sometimes also extract stuff from the t_documents table, but we have not seen this kind of obfuscation(?) before.
Why "SS"?
Maybe it's short for "Sparx Systems" - you have a "Sparx Systems" ZIP format!
