Author Topic: API to force a refresh of diagram image (used in WebEA) after diagram change?  (Read 7490 times)
OpenIT Solutions
Is there an API to force a refresh of the diagram image used by WebEA ? If i make a change to a diagram via API, the diagram image is not refreshed. How can i force a refresh ?
Jon.
OpenIT Solutions
Anyone any ideas on this one ? Does an API exist to force diagram image regeneration ?
There is an option in EA to automatically update the diagram and image maps used by WebEA
Configure | Model | Options | Cloud | Auto Create Diagram Image and Image Map (each time a diagram is saved)
OpenIT Solutions
Yes, i've set that. Problem is that if you update a diagram via API/code, then use diagram.update the image is not refreshed. So i was hoping there was an API/code option. I'll raise a support ticket and see what is recommended.
Jon.
