Author Topic: EA crashes when generating document on very high resolution  (Read 4676 times)
« on: October 16, 2020, 08:51:03 pm »
If you set the option Image Type to bitmap, and the (new) option Image Quality to "Very High Resolution" then EA crashes when generating a document of the selected package containing a large diagram.
The happens with any template containing diagrams I tested with, including the standard model report or diagram report.
Reported
Sunshine
  • Its the results that count
Re: EA crashes when generating document on very high resolution
« Reply #1 on: November 07, 2020, 10:04:03 am »
Which version and build Geert?
Happy to help
« Reply #2 on: November 07, 2020, 05:58:20 pm »
Dat was on 15.1.1529 and also on 15.2.1554
Sunshine
« Reply #3 on: November 09, 2020, 05:55:31 pm »
Just installed V15.2 Build 1555 so though I try to reproduce the problem however, when it came to selecting image quality there are only two options "High" or "Low". So that fixes that problem. ;D  Which is probably an easy way of fixing it. But perhaps doesn't give you the very high resolution you may have required.
Happy to help
« Reply #4 on: November 09, 2020, 06:05:58 pm »
I think you must be looking at another option.
The one I'm talking about is the Image Quality dropdown on the Generate Documentation popup: https://imgur.com/SArvJR0
It still contains the Very High Resolution in v15.2.1555
