Author Topic: Tagged Values and Properties not visible at the same time in 15.x  (Read 3816 times)
Pawel Jasinski
I have just started using sparx 15, and perhaps I am still missing something.
So in 14, I can click on the element on the diagram and see Element Properties window (Name, Type , ... ) and at the same time Tagged Value window with all tags.
Now in version 15, I can't find a way to have a separate window for Element Properties and Tagged Values. All I have is a Property windows with Element and Tags tabs.
So as I click on the elements on the diagram, I am forced to click all the time in Properties and flip between Element and Tags tab.
Am I missing some obvious way to accomplish functionality from v14?
Screenshots available on request.
Cheers
--pawel
Re: Tagged Values and Properties not visible at the same time in 15.x
« Reply #1 on: October 27, 2020, 04:01:38 am »
No, that's it, you are not missing anything.
This isn't an issue for tagged values defined in an MDG as they appear in the same properties window (e.g. BPMN tagged values)
Pawel Jasinski
« Reply #2 on: October 28, 2020, 04:54:32 am »
Thanks Geert,
We have 2 use cases.
1. Models which we can't change with a lot of unprofiled tags. It would be very convenient to see stereotype, object_type and tagged values without additional clik.
2. Models with majority of the tags out of MDG and only some tags added manually. Here the stereotype and object_type are obvious, so we switch to Tags once and are done.
Is there a plugin to overcome this little usability regression?
I mean even a windows which shows us the values without an ability to edit would be an improvement.
« Reply #3 on: October 28, 2020, 08:35:35 am »
I think EAForms sort of did something similar, but I'm not sure if that add-in is still available.
Other then that, I guess it would be fairly easy to write an add-in replicates the old tagged values window.
