Author Topic: Columns in constraint  (Read 6219 times)
Awrel
« on: November 14, 2012, 12:07:00 am »
I am working on a school project - addin to EA to manage Oracle database. I need to know, which columns(and related tables) exist in contraint.
Example:
table CONTAINERS (PK CONTAINER_ID, FK ITEM_ID)
table ITEM_MASTER (PK ITEM_ID)
Now when user makes some changes on table CONTAINERS, column ITEM_ID which is a FK, I need to tell him that this key is from table ITEM_MASTER on column ITEM_ID;
I know how to find tables which I have foreign keys in using SQL, but it's only tables:
"SELECT end_object_id FROM t_connector WHERE (LCASE(connector_type) = 'association' AND start_object_id = " + tableId.ToString() + ") ORDER BY end_object_id"
I thought that this constraint might be in Attribute Constraints, but I get zero from this:
repository1.GetAttributeByID(25).Constraints.Count //table CONTAINERS (ID 16), column ITEM_ID (ID 25)
Maybe it's all wrong, but the information I need can be found in GUI here:
Open table CONTAINERS in project browser, find FK ITEM_ID, right click> "operation properties"> Column> here is the list of Involved columns - ITEM_ID, which is what I need + I need to know from which table this column originates.
I searched entire eap database and found nothing.
Please help.
Re: Columns in constraint
« Reply #1 on: November 14, 2012, 12:59:37 am »
repository1.Get[highlight]Attribute[/highlight]ByID(25).Constraints.Count //table CONTAINERS (ID 16), column ITEM_ID (ID 25)
Open table CONTAINERS in project browser, find FK ITEM_ID, right click> [highlight]"operation properties[/highlight]"> Column> .
Start searching in the operations to begin with. ;D
The involved columns seem to be defined as parameters.
« Last Edit: November 14, 2012, 12:59:59 am by Geert.Bellekens »
Awrel
« Reply #2 on: November 14, 2012, 03:19:05 am »
Thanks for the reply. I did try it before, but now I got a bit further:
EA.Method method1 = repository1.GetElementByGuid("{DEDDFCBE-6DAA-455e-84E7-F719533D2875}").Methods.GetAt(1); //GUID of table CONTAINERS
name = method1.Name; //ITEM_ID_CONTAINERS - this is correct FK name of this table
EA.MethodConstraint methodConstraint1 = method1.PostConditions.GetAt(0); //Index out of bounds, same with PostConditions
Also both tables t_operationposts and t_operationpres seems empty in Access, I am not sure, if I can rely on this. Is PostConditions or PreConditions the correct place where to find details (columns) of the FK ITEM_ID_CONTAINERS?
« Last Edit: November 14, 2012, 03:19:53 am by Awrel »
« Reply #3 on: November 14, 2012, 04:38:00 am »
Have you looked at the parameters as I suggested?
Awrel
« Reply #4 on: November 23, 2012, 04:37:20 am »
I did, thanks, it helped me to find what I needed.
Awrel
« Reply #5 on: December 18, 2012, 02:56:12 am »
Hello again,
I forgot that primary and foreign keys dont always have same names. For example tables
employer(PK ID)
employee(PK ID, FK EMPLOYER_ID)
When I setup something on employer.id I need to find connected column, which is employee.employer_id
The procedure where I go thru constraints(Table.Method where Table is an Element) and their columns (Table.Method.Parameters) doesn't work here, because I can't connect these two column with different names.
I think I need to use Table.Connectors, but I only get FK names from StyleEx which is for example FK_EMPLOYEE_EMPLOYER, again, I can't resolve concrete column.
I also checked ClientEnd property which leads me to ConnectorEnd object, but it doesn't contain column name.
Long story short, I need the brackets from this picture
https://www.dropbox.com/s/dmy9r3rgsm6r27n/keys.png
(EMPL_ID=ID)
and relevant table names.
Please help.
Awrel
« Reply #6 on: December 18, 2012, 06:25:03 pm »
Just looking at the contents of the t_connector table should get you further.
I see:
- SourceRole and DestRole which correspond to the names of the FK/PK operations
- Name in the form of (ColumnName = ColumnName)
- StyleEx in the form of "FKINFO=SRC=FK_name :DST=PK_Name:;"
I think it would be best to rely only on the StyleEx field.
Awrel
« Reply #7 on: December 19, 2012, 10:09:48 pm »
Thanks for help. I hope it's finally done.
I have null values in column Name in T_CONNECTOR, so I had to use this table to find which FK/PK is involved and then go thru start/end_object_id table.methods.parameter and get the column.
Not pretty but working :)
