Author Topic: Reverse Engineering c++: Unexcepted Sysmbol "  (Read 4013 times)
VenkateswB
« on: October 30, 2020, 02:04:15 am »
Hi Forum,
I have a line of which is very important "using vac::container::operator""_sv;", when I try to import this line give me error unexcepted error ". I try to define a Lamguage macro but still not sure, If I comment this line everything works fine.
Please let me know how skip or add this line in EA Import.
Thanks & Regards,
Venkateswarlu Borra
Re: Reverse Engineering c++: Unexcepted Sysmbol "
« Reply #1 on: October 30, 2020, 08:29:14 am »
Looks like we haven't added support for C++11 user defined literals.
The best suggestion I have is to trick the parser into not seeing it. The parser will always go into the first preprocessor branch it doesn't know is false. So something like the following will mean EA will skip over that define without impacting the actual compile.
#ifdef _SPARX_HACK
#else
#endif
If you want something better, you'll have to make a full report to Sparx Systems and they may be able to patch the grammar to handle that code.
VenkateswB
« Reply #2 on: November 11, 2020, 07:24:02 pm »
Hi Eve,
Thank you for the reponse. Yeah the solution worked for me.
But I would like to as if we can get some how the features supported and not supported in c++11, 14 list it would be great
Thanks & Regards,
Venkateswarlu Borra
