Author Topic: UML Profiles  (Read 6665 times)
caitken
UML Profiles
« on: December 19, 2012, 04:56:40 pm »
I'm developing an MDG Technology and want to be able to limit the relationships allowed between elements of the profile to only those defined with the stereotypes in the profile. Any pointers on how to achieve this would be appreciated.
Re: UML Profiles
« Reply #1 on: December 19, 2012, 08:14:52 pm »
You can not really limit them. The quick linker just presents the useful subset of connectors. But via the standard toolboxes one can create any UML-valid connector. If you really want to do a check you need to intercept the creation via the OnPreNewConnector event.
caitken
Re: UML Profiles
« Reply #2 on: December 20, 2012, 08:43:48 am »
Thanks. I noticed that the BPMN MDG Technology doesn't allow flows to cross pools - does it use the same call to police this rule? or a different approach?
Re: UML Profiles
« Reply #3 on: December 20, 2012, 09:11:23 am »
Haven't developed that, you need to ask Sparx...
Re: UML Profiles
« Reply #4 on: December 20, 2012, 09:22:30 am »
I'm afraid it's done in EA, not the technology
caitken
Re: UML Profiles
« Reply #5 on: December 20, 2012, 10:17:53 am »
Is there no way that I could implement something similar using Constraints in EA? i.e., a constraint on the stereotype that checks the type of the source and destination?
Re: UML Profiles
« Reply #6 on: December 20, 2012, 10:41:13 am »
Unfortunately not.
qwerty gave you the answer that you need to write an add-in that implements the EA_OnPreNewConnector broadcast event.
caitken
Re: UML Profiles
« Reply #7 on: December 20, 2012, 11:01:02 am »
Are there any plans to add relational integrity checking to the core product?
caitken
Re: UML Profiles
« Reply #8 on: December 20, 2012, 04:54:40 pm »
I'll take that as a - no.
Re: UML Profiles
« Reply #9 on: December 20, 2012, 04:59:29 pm »
Or you could take it as an "I don't make those decisions". It's certainly a feature I would like to see in EA.
