Author Topic: Diagram.swimlaneDef read only ?  (Read 5395 times)
Ian Mitchell
« on: November 02, 2020, 09:36:20 pm »
My routine to duplicate a diagram stopped working correctly sometime recently (mayby at 15.something...) Using 15.2.
Looks like in Ea.Diagram, we're now supposed to use Diagram.SwimlaneDef instead of diagram.swimlanes. A good improvelemtn, as it makes making changes to swimlanes a lots simpler.
But the new diagram.SwimlaneDef property is showing as read-only (documentation says read/write). So I can't copy the old swimlanes to the new diagram.
@Sparx - is this a bug, or am I missing something ?
The old way very nearly works: it creates entries in t_xref for each swimlane, but it forgets to write 'Swimlane' into t_xref.type. Adding that back makes everything OK, but I feel this isn't the right way to be doing things.
Please can we make it read/write? Or did I miss something ?
« Last Edit: November 02, 2020, 09:38:35 pm by Ian Mitchell »
www.eaDocX.com
www.theartfulmodeller.com
Re: Diagram.swimlaneDef read only ?
« Reply #1 on: November 03, 2020, 03:03:39 am »
Ian,
The SwimlaneDef is readonly in the same way EA.collections are readonly.
You can't Set the object itself, but you can change it's properties just fine.
So you can't do
MyDiagram.SwimLaneDef = otherDiagram.SwimLaneDef
But you can do
MyDiagram.SwimLaneDef.Bold = otherDiagram.SwimLaneDef.Boldand do that for each of the propertis of the SwimLaneDef
Ian Mitchell
« Reply #2 on: November 03, 2020, 07:07:43 pm »
Ah - I see.Thanks
That works perfectly, but with some really pathetic code.
Oh - and the swimlaneDef.swimlane.width seems to always return 200, so I had to go fishing into t_xref anyway, to find and set the real swimlane width. :-(
Time for a ea.diagram.copy method @Sparx please?
« Last Edit: November 03, 2020, 08:06:03 pm by Ian Mitchell »
www.eaDocX.com
« Reply #3 on: November 03, 2020, 07:30:54 pm »
Ian,
What I do if I want to copy a diagram is:
- create a temporary package
- move the diagram to this package
- clone the package
- move the diagram back to where it came from
- move the cloned diagram from the cloned package to where I need it to be
- delete the cloned package
- delete the temporary package
But I agree, Diagram.Clone would be easier  ;D
Ian Mitchell
« Reply #4 on: November 03, 2020, 08:10:56 pm »
Good grief. The things we have to do.
Do you also sacrifice a chicken and throw salt over your shoulder!
..but your way looks more future-proof
www.eaDocX.com
« Reply #5 on: November 03, 2020, 08:20:18 pm »
I already started typing "It's not as complex as it looks." But then I looked at the actual code I was using, and yeah, maybe it it as complex as it looks.
Anyway, here's the code I use:
function copyDiagram(diagram, targetOwner)
dim copiedDiagram as EA.Diagram
'initialize at nothing
set copiedDiagram = nothing
'get the owner package
dim ownerPackage as EA.Package
set ownerPackage = Repository.GetPackageByID(diagram.PackageID)
'check if we need to lock the package to clone it
if isRequireUserLockEnabled() then
dim ownerOfOwnerPackage as EA.Package
if ownerPackage.ParentID > 0 then
set ownerOfOwnerPackage = Repository.GetPackageByID(ownerPackage.ParentID)
if not ownerOfOwnerPackage.ApplyUserLock() then
'tell the user we couldn't do it and then exit the function
msgbox "Could not lock package " &  ownerPackage.Name & " in order to copy the diagram " & diagram.Name,vbError,"Could not lock Package"
exit function
end if
end if
end if
'then actually clone the owner package
dim clonedPackage as EA.Package
set clonedPackage = ownerPackage.Clone()
' if isRequireUserLockEnabled() then
' clonedPackage.ApplyUserLockRecursive true,true,true
' end if
'then get the diagram corresponding to the diagram to copy
set copiedDiagram = getCorrespondingDiagram(clonedPackage,diagram)
'set the owner of the copied diagram
if targetOwner.ObjectType = otElement then
copiedDiagram.ParentID = targetOwner.ElementID
else
copiedDiagram.PackageID = targetOwner.PackageID
end if
'save the update to the owner
copiedDiagram.Update
'delete the cloned package
deletePackage(clonedPackage)
'return the copied diagram
set copyDiagram = copiedDiagram
end function
function deletePackage(package)
if package.ParentID > 0 then
'get parent package
dim parentPackage as EA.Package
set parentPackage = Repository.GetPackageByID(package.ParentID )
dim i
'delete the pacakge
for i = parentPackage.Packages.Count -1 to 0 step -1
dim currentPackage as EA.Package
set currentPackage = parentPackage.Packages(i)
if currentPackage.PackageID = package.PackageID then
parentPackage.Packages.DeleteAt i,false
exit for
end if
next
end if
end function
function getCorrespondingDiagram(clonedPackage,diagram)
dim correspondingDiagram as EA.Diagram
dim candidateDiagrams
dim getCandidateDiagramsSQL
dim packageIDs
packageIDs = getPackageTreeIDString(clonedPackage)
getCandidateDiagramsSQL = "select d.Diagram_ID from t_diagram d " & _
" where d.name = '" & diagram.Name & "' " & _
" and d.Package_ID in (" & packageIDs& ") "
set candidateDiagrams = getDiagramsFromQuery(getCandidateDiagramsSQL)
'if there is only one candidate then that is the one we take
if candidateDiagrams.Count = 1 then
set correspondingDiagram = candidateDiagrams(0)
end if
'if there are multiple candidates then we have to filter them
'first create a dictionary with the diagrams and their owner
dim candidateDiagramsDictionary
set candidateDiagramsDictionary = CreateObject("Scripting.Dictionary")
dim currentDiagram
for each currentDiagram in candidateDiagrams
'add the diagram and its owner to the dictionary
candidateDiagramsDictionary.Add currentDiagram, getOwner(diagram)
next
dim currentowner
set currentOwner = nothing
'filter the diagrams until we have only one diagram left
set correspondingDiagram = filterDiagrams(candidateDiagramsDictionary,diagram, clonedPackage, currentOwner)
'return the diagram
set getCorrespondingDiagram = correspondingDiagram
end function
function filterDiagrams(candidateDiagramsDictionary,diagram, clonedPackage, currentOwner)
dim filteredDiagrams
dim filteredDiagram as EA.Diagram
set filteredDiagram = nothing
set filteredDiagrams = CreateObject("Scripting.Dictionary")
if currentOwner is nothing then
set currentOwner = getOwner(diagram)
end if
'compare the diagrams and their owner with the current owner
dim candidateDiagram as EA.Diagram
dim candidateOwner
for each candidateDiagram in candidateDiagramsDictionary.Keys
set candidateOwner = candidateDiagramsDictionary(candidateDiagram)
if candidateOwner.Name = currentOwner.Name then
'add the diagram to the new list
filteredDiagrams.Add candidateDiagram, getOwner(candidateOwner)
end if
next
'check the number if we have reached he level of the cloned package, or if there is only one diagram left
if filteredDiagrams.Count = 1 _
OR currentOwner.ObjectType = otPackage AND currentOwner.ParentID = clonedPackage.PackageID then
'return the first one
set filteredDiagram = filteredDiagrams.Keys()(0)
else
'go one level deeper to filter the diagrams
set currentOwner = getOwner(currentOwner)
set filteredDiagram = filterDiagrams(filteredDiagrams,diagram, clonedPackage, currentOwner)
end if
'return filtered diagram
set filterDiagrams = filteredDiagram
end function
function getOwner(item)
dim owner
select case item.ObjectType
case otElement,otDiagram,otPackage
'if it has an element as owner then we return the element
if item.ParentID > 0 then
set owner = Repository.GetElementByID(item.ParentID)
else
if item.ObjectType <> otPackage then
'else we return the package (not for packages because then we have a root package that doesn't have an owner)
set owner = Repository.GetPackageByID(item.PackageID)
end if
end if
'TODO: add other cases such as attributes and operations
end select
'return owner
set getOwner = owner
end function
function isRequireUserLockEnabled()
dim reqUserLockToEdit
'default is false
reqUserLockToEdit = false
'check if security is enabled
if Repository.IsSecurityEnabled then
dim getReqUserLockSQL
getReqUserLockSQL = "select sc.Value from t_secpolicies sc " & _
"where sc.Property = 'RequireLock' "
dim xmlQueryResult
xmlQueryResult = Repository.SQLQuery(getReqUserLockSQL)
dim reqUserLockResults
reqUserLockResults = convertQueryResultToArray(xmlQueryResult)
if Ubound(reqUserLockResults) > 0 then
if reqUserLockResults(0,0) = "1" then
reqUserLockToEdit = true
end if
end if
end if
isRequireUserLockEnabled = reqUserLockToEdit
end function
« Reply #6 on: November 04, 2020, 02:59:38 am »
Where is the chicken?
« Reply #7 on: November 04, 2020, 04:03:23 am »
No chicken sacrifices needed, don't worry. This code is perfectly safe, as long as you don't read it backwards out-loud. :o
