Author Topic: «codeEntry» tagged values are not shown  (Read 12670 times)
« on: November 12, 2020, 06:39:10 pm »
When using the UPCC3 Enum library, the tagged values for «codeEntry» values are not shown in the properties window (and also not in the tags tab)
The only way to show the tagged values is to open up the attribute details dialog and select the Tagged Values section.
Steps to reproduce
- Create a diagram of type UPCC3 - EnumLibrary
- Add a «ENUM» element from the toolbox
- Add a «codelistEntry» attribute from the toolbox
- Select the new codelistentry
- Check the properties window and notice that the tagged values "status" and "codename" are nowhere to be found. Not in the properties section (where they should be) but also not in the Tags tab.
Current workaround:
- Press F9 to open the attribute details dialog and select Tagged Values
- Notice that the tagged values are visible here.
Reported
