Author Topic: Partly hidden stereotyped connector with shapescript to change the color  (Read 10379 times)
Guillaume
    • www.umlchannel.com
I have created a number of stereotyped "Connectors" that have an enum tagged value e.g. Type.
I wrote a shapescript to change the line colour according to the tagged value:
shape main{
if (HasTag('type','A'))
SetPenColor(0, 0, 0); //Black
if (HasTag('type','B'))
SetPenColor(255, 255, 0); //Yellow
if (HasTag('type','C'))
SetPenColor(255, 165, 0); //Orange
DrawNativeShape();
This works well except that part of this connector is hidden. If I move it around, it's more or less hidden (it can even be fully hidden if I set the line style to Direct):
I wonder if the sterelotype label (which I hide) could generate some kind of conflict.
Am I missing something in my shapescript?
Guillaume
Guillaume
Re: Partly hidden stereotyped connector with shapescript to change the color
« Reply #1 on: November 21, 2020, 04:27:23 am »
Looks good to me. Probably an EA version issue? I know Shapescript gets hickups when you use shapes at the ends and bend the  connector (I should report that as bug, but it's wasted time since it won't be fixed anyway).
« Reply #2 on: November 23, 2020, 08:10:26 am »
Is DrawNativeShape() allowed with connectors? Try moveto(0,0); lineto(100,0); instead.
Uffe
« Reply #3 on: November 23, 2020, 06:27:43 pm »
Yes, it is. But it doesn't do anything in a connector script.
/Uffe
« Reply #4 on: November 23, 2020, 06:34:12 pm »
As per help it's explicitely not allowed. I'm surprised! Anyhow, if you care, I had a shape with a ball similar to the nesting connector. Cut down:
shape target{
Ellipse(0,-8,16,8);
shape main {
MoveTo(0, 0);
LineTo(90,0);
which sort of looked ok. Until you make a bend somewhere. Just see what happens...
Guillaume
« Reply #5 on: November 23, 2020, 06:36:23 pm »
Thank you for the advice.
It partially sorted the issue as the line is properly rendered. I have to redraw the arrow end which is not rendered with the custom line, but otherwise it's fine.
Guillaume
Uffe
« Reply #6 on: November 23, 2020, 07:19:41 pm »
Not quite. "This method is only enabled for element Shape Scripts; line Shape Scripts are not supported."
The editor allows you to call DrawNativeShape() in a connector script, and the auto-completion also includes it. So the claim that it isn't enabled is simply wrong.
It isn't supported in connector scripts, but the editor permits and in fact encourages you to use it anyway.
/U
« Reply #7 on: November 23, 2020, 07:32:49 pm »
That would be a bug in the editor's intellisense then. Not that I care in any direction...
Uffe
« Reply #8 on: November 23, 2020, 08:00:20 pm »
Well, it seems the editor doesn't recognize whether the script is for an element or a connector. I'd call that poor design rather than a bug.
/U
« Reply #9 on: November 23, 2020, 09:49:42 pm »
/U
Formally, it's a design defect.
« Reply #10 on: November 24, 2020, 08:32:32 am »
It could be both. I've had stereotypes that extend both Class and Association; it makes writing the shape main a bit fiddly but EA copes.
Uffe
« Reply #11 on: November 24, 2020, 07:50:12 pm »
Fair point. And the editor tooltip does tell you that DrawNativeShape() won't work for a connector script. But who has time to read those? :)
/U
