Author Topic: Influence of pools on BPSim simulation capabilities  (Read 6236 times)
ea0620
« on: November 26, 2020, 02:47:51 am »
Hello everyone,
I noticed the BPMN simulation using the BPSim engine has not the same behavior as soon as pools are defined.
Let's define the test case A having the following structure :
<<Package>> Case A
|__<<BusinessProcess>> Case A
      |__<<View>> Case A
      |__<<Activity sub process>> Activity1
            |__<<Activity sub process>> Activity2
                  |__<<Activity task>> Activity3
                  |__<<EndEvent>> EndEvent3
                  |__<<StartEvent>> StartEvent3
            |__<<EndEvent>> EndEvent2
            |__<<StartEvent>> StartEvent2
      |__<<EndEvent>> EndEvent1
      |__<<StartEvent>> StartEvent1
      |__<<BPSim>> Artifact1
This structure consists of 3 nested processes. Each of them contains a start event, an end event and a sub process (Activity1 and Activity2) or a task (Activity3).
Note that we define 1 token on the StartEvent1 start event.
BPSim simulation results shows the token reaches the Activity3. Which is the behavior we expected.
However, including a pool object breaks this simulation behavior. The token doesn't goes to objects nested into the Activity1 sub-process.
Please find the 'Case B' structure.
Let's define the test case B having the following structure :
<<Package>> Case B
|__<<BusinessProcess>> Case B
      |__<<Pool>> Pool1
            |__<<Pool>> Pool2
                  |__<<Activity task>> Activity2
Can anyone enlighten why pool objets usage breaks the simulation behavior ?
Thank you in advance  :)
