Author Topic: Changing an element type to InformationItem  (Read 4160 times)
Modesto Vega
« on: December 08, 2020, 01:47:54 am »
I am trying to use Element\Manage\Change Type to change some element types to InformationItem, and having no success. I am guessing that InformationItem is not a "base type" but an extension of a base type.
Is there a workaround?
Re: Changing an element type to InformationItem
« Reply #1 on: December 08, 2020, 02:46:09 am »
InformationItem is a metatype. I guess it should be possible to change an element into that. If not, you can use scripting and change t_object.object_type to "InformationItem".
« Reply #2 on: December 08, 2020, 04:07:18 pm »
Yeah, they forgot the InformationItem in the Change Type dialog.
I think I reported that issue back in 2009
So if you can be bothered change it via script or database update, if not you'll have to replace the elements with new InformationItems
« Reply #3 on: December 08, 2020, 07:16:59 pm »
And as usual: XMI export, edit, import...
