Author Topic: Scripts within an MDG  (Read 7590 times)
philchudley
« on: December 12, 2020, 02:10:47 am »
Hi All
I believe this may have been posted before, but when generating an MDG using an MTS file it is possible to include scripts which is fine. However when the MDG is imported into a repository, all scripts are lumped together in one group, meaning that if the scripts were written as Browser or Diagram scripts they have now lost this category and cannot be invoked via the Browser / Diagram.
I am using the latest build of EA version 15.2
Is there a after import fix or work around?
Phil
Models are great!
Re: Scripts within an MDG
« Reply #1 on: December 12, 2020, 02:27:30 am »
Not that I know of.
I stopped putting them in the MDG and use only refdata import/export.
I even build myself a tool to select the scripts I need from a refdata file: https://github.com/GeertBellekens/EARefDataSplitter/releases/tag/v1.0.1.0
(automatically including included scripts)
philchudley
« Reply #2 on: December 12, 2020, 02:33:06 am »
Thanks Geert
I too have used the Reference Data Export / Import ... but wanted to only export / import a selection of scripts ... your script looks to suit my requirements and I am going to check it out.
All the best
Phil
Models are great!
philchudley
« Reply #3 on: December 12, 2020, 02:52:54 am »
Hi Geert
I have had a look at the script in Visual Studio and there is a reference to BrightIdeasSoftware for the TreeListView.
I have done a Google Search but all I can find is some references on how to use the TreeListView and a Maths Calculus Software from www.brightideasooftware.com
Where did you get this control from or is it available on your github so I can resolve the reference?
Phil
Models are great!
« Reply #4 on: December 12, 2020, 03:12:15 am »
Phil,
You can download the executable from here https://github.com/GeertBellekens/EARefDataSplitter/releases/tag/v1.0.1.0
But if you want to play with the code, you need the ObjectListview.Offical nuget package
(http://objectlistview.sourceforge.net/cs/index.html)
philchudley
« Reply #5 on: December 12, 2020, 03:24:50 am »
Perfect! Thanks again Geert
Models are great!
Sunshine
  • Its the results that count
« Reply #6 on: December 17, 2020, 09:15:11 am »
Thanks guys that's really useful to know
Happy to help
