Author Topic: Draw shapescript subshapes without color gradient  (Read 8635 times)
« on: December 13, 2020, 06:50:52 pm »
I've been asked to create a shapescript similar to that of the process in EA's analysis toolbox.
I first did with a simple single shape approach, but the problem is that the start and end angles change when resizing the element (because they are defined in relative rather then absolute size)
The solution would then be to use the border layout with preferred width for bot sections, so only the middle section would elongate when changing the size.
This works just fine, with one problem: each subshape keeps it's own color gradient, making it look like three shapes stitches together.
Does anyone know if it's possible to either get
- a gradient over the complete shape
- no gradient at all
Here's wat the result looks like now
https://imgur.com/03s6S9p
And here's the shapescript
shape main
layouttype="border";
noshadow=true;
//set the fill color based on tagged value "heat map"
if(hastag("heat map","good"))
//light green
SetFillColor(112,255,145);
else if(hastag("heat map","problematic"))
//light yellow
SetFillColor(255,253,170);
else if(hastag("heat map","poor"))
//light red
SetFillColor(255,142,142);
else if(hastag("heat map","not evaluated"))
//white
SetFillColor(255,255,255);
else if(hastag("heat map","missing"))
//light purple
SetFillColor(227,168,255);
else
//default white
setfillcolor(255,255,255);
//main shape
setFontColor(0,0,0);
//fillandstrokepath();
//subshapes
StartPath();
addsubshape("left","W");
addsubshape("center","center");
addsubshape("right","E");
Endpath();
FillAndStrokePath();
shape left
noshadow=true;
preferredWidth=20;
StartPath();
moveto(100,0);
lineto(0,0);
lineto(100,50);
lineto(0,100);
lineto(100,100);
endpath();
FillPath();
//draw outline
moveto(100,0);
lineto(0,0);
lineto(100,50);
lineto(0,100);
lineto(100,100);
shape right
preferredWidth=20;
StartPath();
MoveTo(0,0);
lineto(100,50);
lineto(0,100);
endpath();
FillPath();
//draw outline
MoveTo(0,0);
lineto(100,50);
lineto(0,100);
shape right
preferredWidth=30;
shape padding
preferredheight=10;
shape center
startPath();
rectangle(0,0,100,100);
// moveto(0,0);
// lineto(100,0);
// moveto(0,100);
// lineto(100,100);
endPath();
fillPath();
moveto(0,0);
lineto(100,0);
moveto(0,100);
lineto(100,100);
addsubshape("padding","n");
addsubshape("name","center");
shape name
v_align="top";
h_align="center";
printwrapped("#name#");
shape padding
preferredheight=10;
decoration composite
orientation="SW";
if(hasproperty("iscomposite","true"))
ellipse(0,40,40,60);
ellipse(60,40,100,60);
moveto(30,50);
lineto(70,50);
Re: Draw shapescript subshapes without color gradient
« Reply #1 on: December 13, 2020, 07:38:31 pm »
The only alernative is to draw the shape as a whole which then would make the ends stretch relatively. Die the one or the other way :-/
« Reply #2 on: December 13, 2020, 09:56:45 pm »
The only alternative is to draw the shape as a whole which then would make the ends stretch relatively. Die the one or the other way :-/
Hi Geert,
Qwerty is correct.  We stopped using Gradient Fill many years ago.  Unfortunately, for the shapes we create it's more trouble than it's worth.
It's a shame.  Perhaps put in a feature request to allow a parameter to set the whole shape to gradient fill if the background colour is the same?
IIRC you can't gradient fill on a per-shape or per-diagram basis - it would be good if you could.
« Last Edit: December 14, 2020, 08:59:38 am by Paolo F Cantoni »
« Reply #3 on: December 13, 2020, 10:34:52 pm »
Indeed, if I turn off the fradient, or set it to "up" or "down" it looks just fine.
Maybe that is an option for my client, thanks for the suggestion.
I would even be happy with a "nogradient" parameter in the shapescript (similar to the noShadow) so we can turn if off for our shapes.
Takeshi K
    • Sparx Systems Japan
« Reply #4 on: December 14, 2020, 12:29:34 pm »
Helo Geert,
Does the following shapescript satisfy your request?
shape main
noshadow=true;
//delete color setting for the tagged value to be simple
//main shape
startPath();
setfixedregion(80,0,100,0);
moveto(0,0);
lineto(80,0);
lineto(100,50);
lineto(80,100);
setfixedregion(0,0,20,0);
lineto(0,100);
lineto(20,50);
lineto(0,0);
endPath();
fillandstrokePath();
shape name
v_align="top";
h_align="center";
shape padding
preferredheight=10;
t-kouno
« Reply #5 on: December 14, 2020, 05:41:27 pm »
Hi Takeshi,
That works, briljant!
It shouldn't work though.
The documentation says about SetFixedRegion
Fixes a region in a connector into which a sub-shape can be drawn, so that the sub-shape is not rescaled with the length or orientation of the connector line.
For an example, see the 'Rotation Direction' script in the Example Scripts topic.
But I'm glad it does in fact work.
Thanks a lot!
« Reply #6 on: December 15, 2020, 11:40:10 am »
Hi Takeshi-san,
Since, as Geert suggests, you are the "gradient fill sensei", do you have a solution for when you need to place a rectangle over the top of other EA generated glyphs as in:
decoration mydecoration //v1.0 13-Jul-2015
orientation="NE";
if(hasproperty("rectanglenotation","0"))
setorigin("NE",-40,5);
else
setorigin("NE",-20,5);
setpencolor(getuserfillcolor());
setfillcolor(getuserfillcolor());
rectangle(-10,-10,110,110);
shape main
noshadow=true;
//main shape
{ //Icon Form
startPath();
moveto(0,0);
lineto(80,0);
lineto(100,50);
lineto(80,100);
lineto(0,100);
lineto(20,50);
lineto(0,0);
endPath();
shape name
v_align="top";
h_align="center";
shape padding
preferredheight=10;
else
drawnativeshape();
in this code, the oversize rectangle (in mydecoration) is to hide an underlying icon which we want to suppress.
What we want to happen is that this rectangle takes on the underlying gradient at that point.
TIA,
Takeshi K
« Reply #7 on: December 15, 2020, 01:20:41 pm »
Hi Paolo,
Maybe I get what you mean, but I have no idea to satisfy your request in the ShapeScript.
But, the following option might help you.
Double-click the diagram background to open the properties dialog
-> move to the 'Elements' group
  -> uncheck the 'Use Stereotype Icons'
t-kouno
« Reply #8 on: December 15, 2020, 03:48:25 pm »
Hi Paolo,
Thanks, Takeshi-san,
But, unfortunately, not all "icons" are icons (See UML Activity) and so do not respond to the [  ] Use Stereotype Icons setting.  EAUI, I'm afraid.
That's why we have to "overlay" them.
