Author Topic: How to access collaborations (discussions) from VBScript  (Read 6479 times)
michielper
« on: December 16, 2020, 10:04:47 pm »
Some of my elements are linked to a discussion (visible in the Collaboration tab).
How do I access this content from a (reporting-) script?
Re: How to access collaborations (discussions) from VBScript
« Reply #1 on: December 16, 2020, 10:55:55 pm »
IIRC those are stored in t_document
I'm not sure if you can access them via the API
michielper
« Reply #2 on: December 17, 2020, 03:42:14 am »
This is for a script that generates a report.
Might it be that I can use a fragment to show the discussion? This probably works in standard report generation but does it also work with script? My first attempt failed but I was wondering if fragments with SQL code are correctly called from DocumentGenerator.DocumentElement....
Michiel
Uffe
« Reply #3 on: December 17, 2020, 06:14:08 am »
Hi Michiel,
Fragments work the same when called from scripts as when part of regular (F8) document generation. Which is to say, you cannot pass a fragment to DocumentElement() directly, but if you pass a regular template and that template includes a fragment, the fragment is applied correctly.
NB: This applies to SQL fragments, but script fragments won't work when referenced from a generation script because EA's script management is broken and can only deal with one script at a time.
/Uffe
