Author Topic: UML Primitive Types in Stereotype  (Read 3178 times)
Carl
« on: December 21, 2020, 03:00:59 am »
I'm creating a package profile and one of the stereotypes is using a tagged value "problemStatement" which is a hunk of text.  In the stereotype, I'm setting an attribute for the value, but am only able to specify the Java types (which don't include string).  Is there a way for me to select UML Primitive Types? I'm not trying to generate any code for this.
I set all the coding languages from Java to "none" that I could find on the packages and diagrams.
Carl
Re: UML Primitive Types in Stereotype
« Reply #1 on: December 21, 2020, 06:00:32 am »
You don't need to set the type of your attributes in the stereotypes.
If you use the profile helper, you don't have to worry about things like that.
