Author Topic: MDG: Stereotyped Port --metaconstraint 'umlRole = type'-> Interface for drop as  (Read 8352 times)
Somebody
I tried the following:
from: https://sparxsystems.com/enterprise_architect_user_guide/14.0/modeling_tools/metaconstraint.html
it worked for most of the stereotyped metaclasses as expected, but not for a stereotyped port. Let me call my stereotyped Port "MyPort" it appears in the 'Drop as:' drop down list of my stereotyped Interface "MyInterface", but if i select "MyPort" and usually should be created as a Port on a element i droped it to, it is neather fixed to the edge of that element nor visable..
In the ProfileDiagramm it looks like:
https://live.staticflickr.com/65535/50778566593_0ff860054b_c.jpg
In the "work-project":
https://live.staticflickr.com/65535/50778538368_e2528d2d57_b.jpg
https://live.staticflickr.com/65535/50779415802_e372341c83_b.jpg
I don't know if it's a bug or not supposed to - or if i miss something, anyone a clue ?
I'am using 14.1.1427 (Build: 1427) Corporate Edition
Thanks in advance
« Last Edit: January 05, 2021, 01:26:47 am by Somebody »
Somebody
If someone ever has the same Problem, you should "update" your EA Version, I spent a lot of time searching for the Problem..
Not only for this umlRole but also, for instance for the ownedPort it did not work as expected. But it does perfectly with the new Version:
15.2.1557
I downloaded the trial to test it, should have done this earlier..
If such Problems are known a note in the corresponding Version of documentation would be appreciated.
« Last Edit: January 26, 2021, 05:38:43 am by Somebody »
