Author Topic: Describe questionnaire algorithm in UML  (Read 39203 times)
EA_enthusiast
  • I'm a lifelong learner
« on: January 04, 2021, 10:14:52 am »
Hello, EA Experts,
I need your input on the right way to describe a questionnaire in UML. I am trying to model a questionnaire that includes multiple sections as below:
https://ibb.co/WP9CkJ5
Each section is modeled as a class and questions and answers are modeled as Enumeration (in case of multiple-choice questions) or Data Type (in case of free text questions) as below:
https://ibb.co/zJ7R4C1
https://ibb.co/S3g04nL
Is this the right way to do it?
I hope that I have not confused (I feel I might have done so) between modeling the questionnaire at the abstract level (the type of question and types of answers, multiple-choice vs free text) and modeling it at the object/instance level where I state the specific Questions and Answers in each section.
Thank you so much,
Mo
Thank you to all the contributors who spread their knowledge and experience!
Re: Describe questionnaire algorithm in UML
« Reply #1 on: January 04, 2021, 08:38:24 pm »
That does not feel good when looking at it. However, whether or not a model is good or bad depends on the domain which I'm completele unaware of. Also I don't think that this EA forum is well suited to discuss such modeling perspectives in that detail.
« Reply #2 on: January 04, 2021, 08:52:04 pm »
I've seen a fair share of data models, but I'm afraid yours is not good at all.
I would recommend going back to the basics of what classes, datatypes, enumerations and objects are because you seem to be mixing them all up.
Also, your enumerations seem to have only attributes (which is unusual, but possible) and no values at all. I'm not sure if that is deliberate.
Uffe
« Reply #3 on: January 04, 2021, 10:29:49 pm »
Hi Mo,
Unfortunately, I think you have. Don't feel bad -- we all started out making models like this. :)
So here are some thoughts, in no particular order or structure.
A fundamental problem is that in UML, only the syntax and semantics are standardized. No applications are. That is to say, you can't say  "I've done a data model" and expect people to be able to read it. You're still going to have to explain what choices you've made in your modelling methodology, or put another way, what you've modelled, how, and why. (This is sort of what Qwerty is saying too.)
I can think of several different things you might be trying to model here:
  • A conceptual model of what a medical questionnaire is, regardless of whether it's done on paper, by interview or electronically;
  • A data model of the data obtained from a medical questionnaire, with a view to storing it in a database or similar;
  • An activity model of the flow of activity someone follows when filling out a medical questionnaire;
  • A software model of a system for carrying out medical questionnaires.
These are very different things, and it's essentially impossible to know how best to represent anything without knowing what the purpose of the model is.
Your use of enumerations is incorrect.
Enumerations are data types. They should have values only, and are not good representations of questions. They should also be named in the singular. A good enumeration in this context could be "Yes/No Response" with values "Yes" and "No".
I see you've drawn a generalization from Health Assessment to Health Profile. This doesn't make sense; a health assessment is not a type of health profile.
I have a hunch you're more interested in the responses than the questions. If that is the case, focus on the responses. Make each response an attribute in some class, eg "Currently experiencing anxiety, panic attacks or phobias : Boolean".
Don't worry about units of measure if your model is more conceptual than representational. It's a rabbit hole you don't want to dive into unless you really really have to.
I like your «quantity» stereotype and the Duration datatype. But units of measure are not attributes of a quantity: a Duration does not contain one number of years, one number of months and one number of weeks. In general, if you're working with quantities you're in conceptual space and if you're working with units of measure you're in representational space. Don't mix the two. Leave Duration as a primitive (attribute-less datatype).
The «use» connectors to Duration are inappropriate. The «use» relationship denotes usage of functionality, as in one class calling a method in another. If your attribute is typed Duration, that alone expresses the relationship you're trying to show.
So yeah. Room for improvement. :)
/Uffe
EA_enthusiast
« Reply #4 on: January 05, 2021, 04:37:55 am »
Thank you very much q., Geert, and Uffe for your feedback.
I really appreciate you, Uffe, taking the time to provide a detailed response.
I will work on fixing this.
Thank you all.
Mo
