Author Topic: ODBC problems...  (Read 4362 times)
stereotype
ODBC problems...
« on: January 06, 2021, 03:28:31 am »
Migrating from an old work laptop to a brand new one (both with Windows 10 Pro).
On the old laptop I run EA 15.0 and uses the (at least previously) recommended MySQL ODBC driver version 5.1.13 to connect to a database repository. This works just fine.
On the new laptop I installed EA 15.0 and also tried to install the same ODBC driver (5.1.13) but the installation fails due to "Error 1918... can't find ....\myodbc5S.dll".
I googled and found recommendations to install Visual C++ Redistributable Packages for Visual Studio 2013, e.g. https://moreabout.tech/error-1918-while-installing-mysql-odbc-driver-on-windows/. I did that, but it didn't help. Same error.
Googled again and found a recommendation to download myodbc5S.dll and put it in C:\Windows\System32. https://bugs.mysql.com/bug.php?id=81204 That didn't help either.
I can install version 5.1.12 of the driver, but it isn't shown as an alternative when I try to add a new ODBC source...
Also tried to install version 5.3.6, which is recommended in https://sparxsystems.com/enterprise_architect_user_guide/15.0/model_repository/setupmysqlodbcdriver.html but I get the same error...
Any ideas? Thanks!
stereotype
Re: ODBC problems...
« Reply #1 on: January 07, 2021, 07:06:45 am »
Installing a whole bunch of Visual C++ redistributables solved the problem with installing version 5.1.13 of the MySQL ODBC driver...
https://www.techpowerup.com/download/visual-c-redistributable-runtime-package-all-in-one/
